rally wheels
Old Oct 13, 2019 | 09:52 AM
suprkoop's Avatar
suprkoop
Default rally wheels
will the rally wheels from a 70's Chevelle fit my 81? is the offset and backspacing the same? Found a set but don't want to pull the trigger until I'm sure I can use them.
Old Oct 13, 2019 | 09:38 PM
MelWff's Avatar
MelWff
Ask the seller if they are 15x8 with a 4" backspace.
Old Oct 14, 2019 | 11:12 AM
suprkoop's Avatar
suprkoop
he says they are 15 X 8 but he doesn't know the backspacing.
Old Oct 14, 2019 | 02:18 PM
MelWff's Avatar
MelWff
then he should measure it. Measure the distance from the mounting surface to the inside lip of the flange.
Old Oct 14, 2019 | 08:36 PM
sunflower 1972's Avatar
sunflower 1972
Sure about that? I seem to recall Chevelles were 15 x 7. Only C3's were 15 x 8.
Old Oct 14, 2019 | 10:52 PM
60 SHARK's Avatar
60 SHARK
Old Oct 15, 2019 | 08:37 AM
suprkoop's Avatar
suprkoop
they are 15 X 8, maybe he put Corvette rally wheels on his Chevelle which would be what I want.
Old Oct 15, 2019 | 08:41 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
FWIW: All 15x8 Corvette rally wheels are coded AZ. Ask the seller for the code on his wheels.
To rally wheels
