Antifreeze tester
Old Oct 16, 2019 | 07:19 AM
fake's Avatar
fake
Default Antifreeze tester
Have four types all give different readings! Any suggestions on a accurate professional model?
Old Oct 16, 2019 | 10:16 AM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
How far off are the readings from each one?
Old Oct 16, 2019 | 12:27 PM
MelWff's Avatar
MelWff
Are you using the ball gauges that only test concentration or are you using the test strips that measure both concentration and PH level?
Example below
https://www.supplyhouse.com/Hercules...iABEgIaafD_BwE
Old Oct 16, 2019 | 06:45 PM
fake's Avatar
fake
I am using the Prestone guage with a reading on both sides and three different ball guages that seem to place the ***** up equaly three times. No test strips These new products today have little strenght unless you use the manufactures brand
Old Oct 16, 2019 | 06:49 PM
L-46man's Avatar
L-46man
I use a Prestone gauge with the swinging 'density' weight and an Indicator arrow....as long as you hold it straight..it's dead-nuts every time.
I had two...the original one died of the rubber bulb (like a turkey baster) dying of old age....45 years!
Unka
Old Oct 16, 2019 | 08:03 PM
Mod75's Avatar
Mod75
2024 C3 of the Year Winner - Modified
Old Oct 16, 2019 | 08:55 PM
buckybadger45's Avatar
buckybadger45
Unka
I use the same.
Old Oct 17, 2019 | 12:15 AM
l82vett's Avatar
l82vett
I have both the ball type and the swinging weight type. Both suck up the liquid . If I see dark green I'm good no matter what the the thing is suppose to read.
To Antifreeze tester
