ls5 Heads
Old Oct 17, 2019 | 03:07 PM
armstrrw's Avatar
armstrrw
Default ls5 Heads
Are the exhaust/intake ports on the 1971 ls5 (454cid/365hp) round or rectangle? I'm getting ready to replace some disintegrating cork gaskets on valve covers and pan along with the exhaust system gaskets. I note that both round and rectangle shaped gaskets are available for the heads??
Old Oct 17, 2019 | 04:25 PM
Gold Dragon's Avatar
Gold Dragon
Mine are Round..
Old Oct 17, 2019 | 07:34 PM
jkippin's Avatar
jkippin
71 LS5 should be round. You may want to remove a valve cover and check the head casting numbers. Things may have changed over the years.
Old Oct 18, 2019 | 05:54 AM
derekderek's Avatar
derekderek
take a look at the top of the intake runners. there is a bolt there. if it is above the runners,it is oval port or round port. if the bolt is sunk down between the tops of the runners,it is a rectangle port.
Old Oct 18, 2019 | 05:58 AM
derekderek's Avatar
derekderek
oval https://www.ebay.com/itm/1973-78-Che...temCondition=4 rect. https://www.ebay.com/itm/BBC-GM-Mari...temCondition=4
a few aftermarket oval intakes look like rectangle ports. like this weiand stealth. https://www.ebay.com/itm/Weiand-Stea...rd!19061!US!-1 but they use one mold to make oval and rectangle port intakes. they can also be run on either head.
To ls5 Heads
