Temperature Sender Size Issue
Old Oct 21, 2019 | 04:14 PM
chstitans42's Avatar
chstitans42
TheCorvetteBen
Default Temperature Sender Size Issue
I have a 1974 with a 383 stroker motor in it, and it has new style aluminum heads in it. The fitting for the temperature sender is 3/8 NPT and the old sender is 1/2 NPT. All I can find in letric limited's site is listings for the correct reading 1/2 npt size. How can you find a good sender that will make the gauge read correctly with a 3/8 size sender?
Old Oct 21, 2019 | 04:47 PM
stingr69's Avatar
stingr69
Open the hole up to the larger sender size. The pipe tap is cheap and the tap hole required is just a little bigger than the existing hole. Hard to do after the head is installed but easy when it is loose on the bench.
Old Oct 21, 2019 | 04:55 PM
chstitans42
TheCorvetteBen
The head is already on the engine, surrounded by the car and exhaust. There is an easier way than that I hope!
Old Oct 21, 2019 | 05:08 PM
aquaroscoe's Avatar
aquaroscoe
Not the best solution but why not just get the thermostat housing with the bung in it? like this..
Spectre Performance Water Necks 4730 from summit
Old Oct 21, 2019 | 05:09 PM
gjohnson's Avatar
gjohnson
1980 Corvette uses 3/8 and its for gauges so I believe it would be the same reading.
Old Oct 21, 2019 | 05:14 PM
speedreed8's Avatar
speedreed8
I think Wilcox sells one that’s 3/8.
Old Oct 21, 2019 | 05:16 PM
SteveG75's Avatar
SteveG75
Willcox Corvette has a 3/8" NPT sender. $79. You may also need the adjustable resistor. Give them a call.
https://willcoxcorvette.com/corvette...79-3-8-npt-new
Old Oct 22, 2019 | 06:51 AM
AB_in_AUS's Avatar
AB_in_AUS
I have a 79 which was stroked and new heads when the engine was rebuilt. Temperature sensor was miss-matched with the gauge. I got one of these from Wilcox, worked a treat with the original gauge. I didn't need a resistor.
Old Oct 22, 2019 | 12:04 PM
chstitans42
TheCorvetteBen
You guys on the forum are awesome. Thanks!
To Temperature Sender Size Issue
