Dimensions for rear end
Old Nov 9, 2019 | 02:27 PM
RSorange34's Avatar
RSorange34
8th Gear
Default Dimensions for rear end
I am needing the side to side measurement for the trailing arms for a 1980-82 Corvette..can anyone help? Thanks!
Old Nov 10, 2019 | 12:43 PM
MelWff's Avatar
MelWff
Isnt that measurement going to vary based upon the number of shims used to adjust toe-in?
Old Nov 11, 2019 | 07:14 AM
RSorange34's Avatar
RSorange34
8th Gear
I just need an approximate measurement does not have to be exact...I am using this rear end on a hot-rod chassis and I need to get it close enough to take it where it can be adjusted with shims.....I am thinking 45 -1/2" but want to make sure .
Old Nov 13, 2019 | 03:46 PM
Speed Direct's Avatar
Speed Direct
Premium Supporting Vendor
Are you trying to set the toe for a rear end that is already installed? Just use the tape measure technique to set it. Or is for installing the trailing arms on a chassis that didn't have it originally (welding brackets in place)?
Old Nov 13, 2019 | 03:51 PM
bfit's Avatar
bfit
I’ll measure a chassis , and post for you.
bfit
Old Nov 13, 2019 | 07:19 PM
RSorange34's Avatar
RSorange34
8th Gear
rear is already installed but has toe due to frame being narrowed down. looking for close measurement so I know how to fix it as the trailing arms are attached to the frame and will need to be moved. Frame is a 32 ford frame so it did not come with the 1982 rear end
Old Nov 13, 2019 | 07:20 PM
RSorange34's Avatar
RSorange34
8th Gear
Thanks bfit I would appreciate it if you could give me a quick measurement. I appreciate the help!
Old Nov 14, 2019 | 11:33 AM
Speed Direct
We actually have a similar frame/project in our shop. The outside dimension on the frame at the T/A pivot is 47.5" and the inside is 41.5".
Old Nov 14, 2019 | 12:42 PM
RSorange34's Avatar
RSorange34
8th Gear
Thank You Speed Direct! Now I will know how to proceed with fixing my problem...I appreciate it very much!
Old Nov 14, 2019 | 04:08 PM
bfit's Avatar
bfit
I measured two frames and came up with similar measurements+/- a 1/16’’
bfit
Old Nov 14, 2019 | 09:48 PM
RSorange34's Avatar
RSorange34
8th Gear
Thanks bfit...I appreciate the help very much!
To Dimensions for rear end
