C3 Purchase advice thread: "should i get this C3?"
To help others help you, try to include a good bit of info about the car such as :
- a link to the listing, unless you're concerned about lurkers swiping it before you
- the seller's asking price
- year, mileage
- numbers matching or non (claimed by the seller)
- pictures, preferably many, in an easily linkable album such as google photos or imgur.
- location of the car
- relevant info about it
- things you know are wrong about it, or broken on it.
'75 in southern california, this is like the fourth C3 owned by this guy
black on oxblood red
Odo appears to say 80,000
album of 24 pictures: https://photos.app.goo.gl/Z2q7fChV3uRwCoZUA
the seller is asking $13,000 for it, which seems reasonable?
supposedly a lot of interior was replaced in the past 5 years, carpet/upper dash cover/door panels, it has a 3.08 rear end and a 4 speed, he put in the glass from a 69 so it's removable but he hasn't gotten the rubber moulding yet so it isn't water tight. There's a battery disconnect switch installed for long periods of storage.
the paint is a "ten footer" with some imperfections, he noticed paint bubbling on the hood so he sanded it down and put a matte black hood stripe on to cover it.
american racing thruster wheels, 235/60/16 rear, 225/60/16 front
looks like the steering column has also been swapped for a black one.
the engine is "new hipo 350 with Vortec heads and lots of polished alum"
he's selling due to a hip injury, can't drive stick anymore
looks fairly original but the way the battery cut off switch wiring went through the cardboard tray is annoying and would bug me ,certainly not a deal breaker !!!
there's an add on steel bar at the front just behind the licence plate mount (screwed onto one of the two centre reinforcements ) just wondering what that's for ?
close up pic of the wheel shows a smaller than normal brake pad wear on the disc ?
certainly worth a closer look (to me anyway)
https://sandiego.craigslist.org/nsd/...011787241.html
With all that information, it's pretty easy for another interested buyer to poach your lead. But, you also include a lot of information that is not in the listing, so that is very helpful to get input from the forum.
Seems like a well-priced and well mantained car. Perhaps it's the flash that causes the interior to switch between red and dark red.
The homemade battery disconnect is not terrible to fix. Would not be a deal breaker only a concern in terms of if that is how one of the owners came up with a solution for long-term battery storage....what else did they creatively fix on the car?
Thanks for the details. Looks pretty solid to me. Asking price sounds like there is maybe a little more wiggle room on price.
Good luck.
Kevin
Even made a thread to find forum folks to take a look, but no takers yet
Google photo album of about 20 pics
1972, black on black, was repainted at some point because the data plate says it was blue
seller's asking $14,500
ram air scoop just barely peeking out, which i ALMOST like because it only minimally impacts the hood lines. Although i was going to get a short L88 hood on whatever i get, so it's trivial to swap over
Description from the ad:
New in the past 2 years and 1500 miles: Seat covers, Leaf spring, Bushings, Brake pads and calipers, battery, battery switch, gas tank, mufflers, tires.
All gauges work EXCEPT the clock and the oil pressure gauge
This honestly looks pretty promising for the price, i was going to try to talk him down to 13k after i get a prepurchase inspection. Since the paint isn't super great anyway i was just going to toss is on an open-air carrier for about $1500 cross country to san francisco
There's a lot of new england patina around though, that light surface rust looking stuff around the engine bay and on the older suspension parts. Doesn't really bother me but it is "of note"
Obviously, it's about the lowest HP Vette of the era and really kicked off the single exhaust with pollution controls. The torque thrust wheels are great for the period, but again at that price, IMO you should be getting a lot more originality than appears evident.
Everything's more expensive in Southern California, but I've owned five C3s and think this one's over-priced by at least $2k pending a closer look.
Good luck- EDIT: did you see this one? https://sandiego.craigslist.org/nsd/...015144093.html
His ad expired on CL but I still have his number, what goes bad on those? What I must check? And finally any recommended shop to do PPI in Carlsbad/Delmar/Encinitas area? Southern Cali
Watch this, and look for rust.
https://www.youtube.com/watch?v=SgRgAppx0d4
This was the best i can get in terms of photo, even landscape, I am trying to see the car this weekend so will get better pics, hopefully find a good shop to do ppi.
thanks for the video, much appreciated.
the more i get into my new experience working on and buying i have summarized it like this..
is it the car you want...and will like regardless of what breaks.
Although theoretically everything can be fixed or replaced..
rust...other than obvious light surface rust....NO
collision frame. NO
is there enough original parts there if that is what you want?
Price for this car assuming above...10 to 13 k depending on love of car.
done.
follow up on this one, got a lemonsquad vintage report and it looks....alright. I was going to offer him more like 12 grand since there's a ton of little problems all over
https://drive.google.com/drive/folde...BG?usp=sharing
not sure if this link works for anyone else though
what do you guys think?
It's a pretty rough example and his asking of 14.5 is too high but he's quite firm on the price and has other people looking so i'm pretty "eeeh" on it
