front spring install 76
Old Nov 11, 2019 | 05:36 PM
Dirk76's Avatar
Dirk76
Default front spring install 76
getting all parts together for the front end. Ordering the bits i missed.
I am looking online, but i cannot tell if there is one.
With the front spring sitting into the arms, is there a pad or some sort of protection. Or is it straight metal on meta?.
76 model
Old Nov 11, 2019 | 05:42 PM
L-46man's Avatar
L-46man
Metal on metal....drop the lower control arm All the way by removing upper ball joint. I use internal spring compressors and squeeze the springs down a bit...I don't like to struggle.
Good luck.
Unkahal
Old Nov 11, 2019 | 06:12 PM
Dirk76's Avatar
Dirk76
thanks.
For a complete visual reference.
If someone has a borgeson box install on their 76 front end. Can you take a few pics of the whole front end from different angles at all please.
Thanks )
To front spring install 76
