Anyone have this steering issue.
Old Nov 27, 2019 | 09:01 PM
GrantMcGinnity's Avatar
GrantMcGinnity
Default Anyone have this steering issue.
So my car's steering is a little crooked and when driving an awful rattling noise comes from the wheel that only stops if I push down hard. Also open stopping or turning my rear wheels make a sort of knocking noise... not sure if this is a serious problem or something a steering alignment will solve. Car is a 78 with a tilt tele wheel.
Old Nov 27, 2019 | 10:02 PM
l82vett's Avatar
l82vett
It sounds like you need to take you car to a mechanic real quick. Stop driving it around and making the problem worse. If your steering wheel is pulling and you have a noise it's probably a wheel bearing. If you have a rear wheel noise it could be the same [Wheel bearing ] or a half shaft u-joint. Get it fixed. Cheaper before it breaks.
Old Nov 27, 2019 | 11:05 PM
GrantMcGinnity
Default Thanks
[QUOTE=l82vett;1600564388]It sounds like you need to take you car to a mechanic real quick. Stop driving it around and making the problem worse. If your steering wheel is pulling and you have a noise it's probably a wheel bearing. So I just got my suspension re-done the knocking noise is just my new shocks breaking in. As for the wheel seems to be alignment issue due to it getting new suspension. Hopefully that's all it is but will keep thread up cause you never know with these cars.
Old Nov 27, 2019 | 11:31 PM
l82vett's Avatar
l82vett
If your mechanic told you your shocks are making a knocking noise because they are breaking in tells me YOU NEED A DIFFERENT MECHANIC!!!!!!!! shocks don't make noise unless they are broke in half. Who ever did your NEW SUSPENSION should have checked for ball joints , tie rods and wheel bearings for wear. Most places do a front end alignment when suspension parts are changed. What was done when you had your suspension REDONE? Should be on the repair sheet.
Old Nov 28, 2019 | 12:10 AM
GrantMcGinnity
They replaced all my bushings bearings etc... my cars underside was all bone stock from 78... this mechanic is a C3 expert and they do an impecable job and give me good discounts since I'm younger. The alignment issue happend after some engine work and is most likely the culprit. I'm taking it back Friday to get aligned. Will keep you posted.
Old Nov 28, 2019 | 07:23 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
engine work has nothing to do with suspension. There is no way engine work will effect your alignment. I think this guy is taking you for a ride. Does he have any pictures of boats in his office? You may be making the payments on one for him.
Old Nov 28, 2019 | 09:39 AM
GrantMcGinnity
The alignment issue came up after I took it to a different ship prior to all the new suspension. My cars whole rear end was bad and they definently took off my tires and whatnot to see whats up, though I elected to have a classic corvette shop fix my cars rear. If any shop screwed me it was this first 1 not planning on using them again anyway. They did fine on my engine but were very slow.
Old Nov 28, 2019 | 09:56 AM
Rescue Rogers
That makes more sense no. Sorry for the screwing. I think we've all been there at one point or another
Old Nov 28, 2019 | 11:07 AM
l82vett's Avatar
l82vett
For being a C3 expert ,your mechanic sure left you with a lot of problems. You better check your lug nuts before your wheels fall off, NO THIS IS NOT A JOKE!!!!!!
Old Dec 1, 2019 | 01:21 AM
GrantMcGinnity
Default Good news some bad.
So got my car aligned its driving better than ever and steering wheel is straight. Only problem now is when the wheel is even the slightest bit left it makes a squeaking noise kinda sounds like re-winding a vhs. My steerting seems fine so seems like a steering column issue... y'all have any ideas. I have the titl/tele wheel.
Old Dec 1, 2019 | 07:49 AM
bikesnbroadheads's Avatar
bikesnbroadheads
can you determine if the noise is in the column or under the hood? theres not much in a steering column to make any noise. maybe underhood like belt or steering pump? seems like your mechanic would have caught that if it was an unusual noise?
Old Dec 1, 2019 | 08:20 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Keep in mind, there's also a 'power steering ram', that's in the system. They've been known, from time to time, to go bad, and need a rebuild.
Old Dec 1, 2019 | 10:30 AM
croaker's Avatar
croaker
Has anyone checked your power steering pump. Fluid level and belt.
Old Dec 1, 2019 | 08:54 PM
jpatrick62's Avatar
jpatrick62
The squeeling noise definitely sounds like low fluid level - I would open the hood while the car is running. Then have an assistant turn the wheel hard left and then hard right to locate the origin of the trouble.
Old Dec 1, 2019 | 09:04 PM
GrantMcGinnity
Default Update
So, I'm heading back to College but I'm gonna run cleaner through my power steering system and then put in new fluid. My power steering pump was just completely replaced so I assumed new fluid would have been put in... Wish my break was longer so I could work on my car longer.
Old Dec 1, 2019 | 09:07 PM
GrantMcGinnity
Default Also
Whenever I push or hold my steering wheel down the noise stops plus it only occurs when my wheel is between the 10-11 o clock position so close to straight or when making a left.
To Anyone have this steering issue.
