Door glass differences
Dec 13, 2019 | 01:38 PM
Any differences (aside from date code) between L1969 thru 1981 door glass?
Thanks,
G
Dec 13, 2019 | 02:16 PM
Cruise-In II Veteran
Other than the Astro-Ventilation script? The 80-82 glass is supposed to be thinner.
Dec 13, 2019 | 05:26 PM
Yes, the slightly thinner (by 1 mm I believe) glass from '80+ was part of the "diet" that reduced weight.
Dec 14, 2019 | 06:37 AM
Quote:
Originally Posted by
1960fi
Thanks,
G
FWIW, and at the risk of stating what you may already know, convertible side glass is different than coupe side glass.
Sorry if I'm telling you what you know already but felt it's better to be redundant than to miss a point.
Regards,
Don
Dec 14, 2019 | 07:15 AM
Thanks all,
So, will ‘69 glass not interchange into an ‘81 because of the thickness difference?
Dec 14, 2019 | 11:03 AM
a thicker older glass may not slide as well in the later tracks. but if you already have the glass i would try it.
