1977 Euro taillight conversion
. Use a switch back bulb simular to what newer cars use for daytime running lights and directional signal ,
replace the origonal backup light socket, with one to accept the new bulb, , power the amber side of new bulb from your front directional bulb, ( left to left,, right to right ) ,, then power the white side of new bulb from existing backup wires,
. Likely you will never need both backup AND turning signals at the same time,,,
,,, and if you do, it will provide you with one backup light while the other is flashing amber,,,,,,,
Tail Lights and Backup Lights Set For Chevrolet Corvette C3 1975-1979 Smoked | eBay
But, the guidance published above and credited to Corvette Kingdom was actually written by me, and originally printed in the CCCUK Magazine, back in about 1992. (My later version is now copywrited!) Things have moved on a little since that, and many people use "switchback" LED lamps for the reverse and indicator bulbs. But I believe they need a different bulb holder and they do need resistors, or a replacement electronic flasher unit.
My '78 still runs the system described in my article. I have now fitted LED bulbs in the side/brake lights and front side lights, but use regular bulbs in the indicators. I recently fitted a new set of rear lamp lens units and checked all the 30+ year old connections - all good!
