Large void under carpet
Old Dec 17, 2019 | 03:32 PM
Yadkin's Avatar
Yadkin
Default Large void under carpet
This is under the passenger seat. I know what it is- the catalytic converter is below the seat towards the front and middle, and this is what's left over. The PO ripped the carpet and I suppose I can sew it back but I should fill this with fire retardant foam and level it off. Unless anyone has other ideas...
Old Dec 17, 2019 | 04:13 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Sorry, but I can't see much in your pic. As far as flame retardant foam is concerned, what do you feel will burn in that area?
Old Dec 17, 2019 | 04:27 PM
chazde3's Avatar
chazde3
There is normally a void in that area. It's where one of the seat belt retractors is mounted. Why do you feel you need to fill it in with foam?
Old Dec 17, 2019 | 04:43 PM
Yadkin's Avatar
Yadkin
The seat retractors on my '81 are built into the side panels. In order to keep the carpet from re-ripping I'll have to fill the volume (about a quart) with something.
Why fire-retardant foam? Great Stuff makes it, cost is not a lot more than regular foam. I used it to repair a split padded dash a while back, prior to upholstering it with vinyl, and that repair has held up well.
To Large void under carpet
