Engine Hoist Clearance Questions
1) My shop is fairly narrow (about 15 feet wide) and has some things placed against the side walls. I know I'll need to pull the engine from the side. How much side clearance am I going to need to lift the engine and maneuver it?
2) I need to purchase an engine hoist. Prefer a folding model so I can more easily stow it for future use. How much lift height do I need? I have a couple of choices I can pick up locally.
This Strongway at Northern Tool: Link The Strongway has a lift height of just over 82".
This Torin Big Red at Tractor Supply: Link The Torin has a lift height of 89".
Summit has a couple of choices where the lift height is in the 93 - 96" range but those are more expensive. Although I do like what I've read about this Ranger: Link
I've forgotten where I saw it but I also found one hoist with a lift height of around 102".
If any of these will work, is there any reason other than lift height to choose one over the other? Any other recommendations? Not looking for a one and done hoist. I plan to keep this one around to help lift things in and out of vehicles and my trailer.
I do have a QuickJack if that changes anything you might recommend.
Edit: Update below.
DC
What really helps is a "load leveler" and then you can attach 4 short chains to each cylinder head front and back. As you disconnect the trans mount you can kind of get a feel for the balance as you lift it. Get a plug for the trans or it will pour trans fluid all over.
Others can chime in but I wouldn't lift the car other than to get the front tires off for engine hoist clearance.
Bias the car towards the non lifting side of the car in your garage and you should be fine. Helps to have someone, In my case my wife to watch clearance problems. Get's a little scary when you have the engine and trans hanging over the nose of the car.
Oh and cover fenders and everything else with a thick layer of blankets to protect the paint.
Good luck.
But, I don't really trust the dimensional information on the Torin. They are apparently made in the same factory as the owners manuals are very similar including identical dimensional drawings. But the Torin shows to have greater lift range even though most other dimensions are nearly the same as the Strongway.
What hoist do you have?
Thanks for the help.
DC
I did have to pull the engine/hoist out almost perpendicular from the car until the legs cleared. I would think that would be pretty close to a 15 ft distance.
DC
I sort of borrowed an idea from Carrol Shelby- he was pretty good at coming up with them!!!
Raised the back of my car up- my drivetrain is fairly long - a couple extra cylinders and Tremec 5 speed- a MUCH better angle to do it at!!!
Unbeatable deal here:
https://www.summitracing.com/parts/sum-csum905218ki
Jebby
May or may not work in a 15 ft wide space. You may need to go in from the front like richard 454 did.
Any big box store hoist I have ever seen is not long enough to come in from the front.......
There is always the A-Frame style chain falls too! Don't rule it out......the chain fall itself is reasonable and a guy can build an A-frame with a decent welder!
Jebby
DC
Jebby
I really don't see how you can do this with the hood on. Nice part about the fiber glass hood is they weigh hardly anything compared to a steel hood. Scribe around the hinge where it attaches to the hood and get it out of the way.
On the Shelby pic look how long the hoist arm is. Most current commercial engine hoists don't have that length.
https://www.northerntool.com/shop/to...IaAgL8EALw_wcB
It's a V12 with a Tremec 5 speed- pretty long combo and I did it with the Harbor Freight lift a few times-
My basement garage is 12' minimum and 15' where it bumps out x 40' So it is not wide at all...
Specs on Folding "cherry picker" (does anybody call them that anymore???)
- Boom extends from 34 in. to 45 in.
- Crane height adjusts from 69-5/8 in. to 82 in.
I used 2 x 4 blocks to get the rear end up when I put the trans and engine combo in-
None of my car guy buddys live near me. It's a constant struggle to find help let alone on my time line.
DC
Yep. I do plan to get a hoist leveler. Seems like a no-brainer. But, I won't be pulling the engine and tranny together.
Very helpful Richard. Your info and photos makes it look like any of the lifts will work just fine.
Appreciate all of the input.
DC
Also those "L" brackets that come with the leveler chains are waste of time unless you pull the intake. I replaced mine with two chains of similar size and just used the correct size bolts as needed.
Pics of the V12 hanging above a freshly painted car or any car is a bit scary. Glad it worked out.
I got the big block out of my 69 without removing the hood. Just disconnect the hinge so the hood can stand straight up. It was really close but made it.
Good to know. Thanks.
Thanks for the input and confirmation. I remember gkull posting that he never removes the hood to pull an engine so it's good to know that others have had success as well.
DC
