Bad HEI Ignition Module or Coil?
Old Dec 27, 2019 | 02:54 PM
miked123's Avatar
miked123
Originally Posted by jackson
sometimes the "no apparent reason" is simply a bit of crap/crud/schmutz/sh7t partially or fully plugging an orifice or slot. Clean it out.
some times brass floats' seams fail or crack... leaking gas into them and sink; causing flooding.
some times polymer floats begin soaking up gas (gas-logged) then sinking; causing flooding.
that at makes sense, after talking with others on here, I’m going to replace the fuel filter and check the ignition timing. I think the timing is just messed up and needs to be adjusted. I adjusted the carb today but no improvement to the problem I described earlier. It’s gotta be and issue with timing.
Old Dec 27, 2019 | 09:22 PM
C3 Stroker's Avatar
C3 Stroker
I KNOW that ! ......and know the "reason" why. Just letting the OP know that these things sometimes happen with no warning signs.
Old Dec 27, 2019 | 11:08 PM
jackson's Avatar
jackson
And so was I ... cool your jets ... good, bad or indifferent nothing 'bout you was implied either way ... not even on my radar.
Happy, Healthy New Year for all.
Old Dec 28, 2019 | 08:50 PM
C3 Stroker's Avatar
C3 Stroker
I hear ya. No harm, no foul .....Happy, Healthy New Year
