1981 brake calipers
Old Dec 24, 2019 | 07:30 PM
linkedge540's Avatar
linkedge540
Default 1981 brake calipers
I just recently purchased a 1981 c3 and I’m replacing the complete steering system, gear box, power steering valve, hydraulic ram and all the power steering lines. What a PIA I have bent my first pitman arm puller trying to get it off. The power steering valve took hours to get it off. What I’m interested in is replacing the brake calipers there are so many options out there. What is the difference between the lip seal and o ring. I want stainless steel lined. Where is the best place to get them.
Old Dec 25, 2019 | 04:31 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Buy a FIRE extinguisher and a handheld propane "torch" . After you install the puller heat the joint with the torch. Shield all flammable nearby hoses, fiberglass, fuel lines & tank, etc from ALL torch heat.
Old Dec 25, 2019 | 06:10 PM
linkedge540
Yea that’s what I’m going to try tomorrow morning
Old Dec 25, 2019 | 07:10 PM
av81's Avatar
av81
I never heard of using a touch to remove steering parts , a swing of a hammer placed hard on the right spot always worked for me. Sometimes with the puller installed as tight as possible.
Old Dec 27, 2019 | 03:10 PM
jim-81's Avatar
jim-81
As far as the steering system, if you haven't purchased all of those replacement items, check into the Borgeson gearbox system. It's a nice upgrade over stock. Many threads on it in here including mine.
Jim
To 1981 brake calipers
