Adjustable DC Power Supply?
Old Jan 1, 2020 | 02:28 PM
Emeightch's Avatar
Emeightch
Default Adjustable DC Power Supply?
Any recommendations on one of these without spending too much? Learning to do some bench testing on my gauges. It’s getting too cold in Detroit to be working through these electrical issues outside!
Old Jan 1, 2020 | 02:42 PM
ntfday's Avatar
ntfday
Veteran: Marine Corps
I made one from an old computer tower power supply, it's not adjustable though it's a stable 12vdc
Old Jan 1, 2020 | 02:52 PM
ignatz's Avatar
ignatz
If you have an old car battery and a charger, you are in business already...
As to variability, if you are tweaking various sources to see what the gauges do, a voltage divider will do the trick
Otherwise look here:
https://www.sciplus.com/s/?q=dc+power+supply
for a few choices of commercial sources, I've got the lab supply or something very similar and you can set a current limit which is a nice feature. Might be made in China, though.
One additional note, if you want to replicate the car's voltage, when it's running, the supply side is more like 14 VDC, so you would want some adjustability in your supply.
Old Jan 1, 2020 | 05:53 PM
Richard454's Avatar
Richard454
Here you go-
Back in the day - 20+ years the company I worked for was a distributor for these power supplies. I have a couple that have been used (and abused) and still work great!! They still look the same!
Astron- Made in the USA and a 7A piece with 13.8VDC is under $80.
https://www.universal-radio.com/cata...ps/astron.html
https://www.universal-radio.com/catalog/hamps/2506.html
Old Jan 1, 2020 | 06:53 PM
Dazaa Rafae Aman's Avatar
Dazaa Rafae Aman
Look on ebay for an old bench dc power supply, they can be had for next to nothing(30/50 bucks) and easily found. I’d be lost without mine.
Old Jan 1, 2020 | 07:21 PM
Emeightch's Avatar
Emeightch
So I know I want adjustable voltage. I know the battery ranges from 12V-14V. The highest amperage fuse/breaker I see in the fuse block is 30A for the power windows (which don’t want to work either). Do I need to buy one that handles max volts & amps?
Old Jan 1, 2020 | 08:09 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
I have been using one of these a lot lately.......it is the bomb dot com:
Amazon Amazon
Shoot power anywhere you want.......check anything you want on the go......
Jebby
Old Jan 2, 2020 | 03:17 PM
Emeightch's Avatar
Emeightch
... and do I want linear or switching supply?
Old Jan 2, 2020 | 03:40 PM
Richard454's Avatar
Richard454
If it's sitting on the bench- a linear type would be the best- it's quieter- cleaner but heaver and generates more heat-
A 30 A will run anything you have in your car ( not all at the same time) except the starter.
Again- I really don't know what you want to accomplish...
I have my big power supply on the bench to test wiper motors-electric headlight motors- headlights-fans- car audio amps-
When I'm working on a car- I'll have the battery in place and use the 7A connected to the battery to keep it charged while I test various electrical- it ensures the battery has a fully charge with out starting it.
MOST battery tenders- chargers tend to be really noisy- especially if you are doing a radio or electronics - as they are not filtered as good as a power supply.
Richard
Old Jan 2, 2020 | 05:21 PM
L-46man's Avatar
L-46man
Default La Volta DC power supply...'twas cheap.
Here is mine...and I love it....If it was a car it would have a million miles on it.
amazon cheap! years and years of service! $90 delivered.
Old Jan 2, 2020 | 08:13 PM
Emeightch's Avatar
Emeightch
So I’ve decided to use up some gift cards from Home Depot... should be more than enough for the bench testing I want to do.
UNI-T UTP3315TFL-II Linear DC 0-Volt to 30-Volt/0 Amp-5 Amp Power Supply, Stabilized & Adjustable Regulator W/4 Digit Display.
Old Jan 2, 2020 | 11:32 PM
Richard454's Avatar
Richard454
good deal-
Even though the power supply has built in protection- a few bucks for a fuse holder in line is well worth it!!!
Old Jan 3, 2020 | 03:48 AM
hunt4cleanair's Avatar
hunt4cleanair
Well this is a most interesting discussion and timely for me as well. I've got three mechanical clocks I'm tinkering with, one works and two I need to restore so I'm like Emeightch. Over time, I've found myself testing headlamps, probing in-car components and always have wires running all over the place, clips, probes, whatever it takes.
I get the impression to have a bench source like this UNI-T UTP3315TFL-II Linear DC 0-Volt to 30-Volt/0 Amp-5 Amp Power Supply, as well as something like the Power Probe III Clamshell, are complimentary. Or are they redundant? Apparently, the probe is for work inside the vehicle while the bench source is for testing components on the bench.
Like recently, I used a noisy battery charger on a battery as my 12v source to test a clock, but as noted above...noisy!
Old Jan 3, 2020 | 01:15 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
The power supply plugs into the wall......the power probe uses a 12v battery. It is up to you how you want to get your power but yes.......they both can do the same thing......
Jebby
Old Jan 3, 2020 | 06:27 PM
Richard454's Avatar
Richard454
Jebby
Or you could hook the power supply to the Power Probe...
Basically- The power probe acts as a set of jumper cables NOT as a power source/supply.
Old Jan 3, 2020 | 06:43 PM
loup68's Avatar
loup68
Army
What about an HO train set DC "power pack" for things like gauges and clocks? Lou.
Old Jan 4, 2020 | 12:03 PM
jackson's Avatar
jackson
over a hundred new ones to choose from
https://www.amazon.com/s?k=dc+bench+power+supply+variable&i=industrial&crid=1PWXRLWYQRZCN&sprefix=dc+bench%2Cindustrial%2C151&ref=nb_sb_ss_i_2_8 https://www.amazon.com/s?k=dc+bench+power+supply+variable&i=industrial&crid=1PWXRLWYQRZCN&sprefix=dc+bench%2Cindustrial%2C151&ref=nb_sb_ss_i_2_8
To Adjustable DC Power Supply?
Old Jan 5, 2020 | 03:52 AM
hunt4cleanair
Anyone see a problem with this DC power supply? I like the green on/off button.
Dr.meter 30V/5A DC Bench Power Supply Single-Output 110V/220V Switchable with Alligator Clip Included, US 3-Prong Cable,PS305DM
https://www.amazon.com/Dr-meter-Single-Output-Switchable-Alligator-included/dp/B00O8DJ8QC/ref=sr_1_9?crid=1PWXRLWYQRZCN&keywords=dc+bench+power+supply+variable&qid=1578212907&s=industrial&sprefix=dc+bench%2Cindustrial%2C151&sr=1-9 https://www.amazon.com/Dr-meter-Single-Output-Switchable-Alligator-included/dp/B00O8DJ8QC/ref=sr_1_9?crid=1PWXRLWYQRZCN&keywords=dc+bench+power+supply+variable&qid=1578212907&s=industrial&sprefix=dc+bench%2Cindustrial%2C151&sr=1-9
Old Jan 5, 2020 | 09:48 AM
Emeightch's Avatar
Emeightch
The Dr. Meter is what I was going to go with initially. The stability was pretty good. It’s also a linear supply.
Old Jan 5, 2020 | 09:49 AM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
Thinking about a dc power supply also. Would a 30V-10A be better than a 30V-5A for automotive use?
