defroster switch
Old Jan 21, 2020 | 11:17 AM
Elpica81's Avatar
Elpica81
Cruising
Default defroster switch
Hi hope everyone is having a great year. the other day i replaced my shift boot on my 81 vette. when i assembled the console i notice that the defroster light was on an wont go off as well as the A/C is not blowing. I don't know if because the defroster light is on or a separate issue. any suggestions?
Thank you
Old Jan 22, 2020 | 12:50 PM
Street Rat's Avatar
Street Rat
Thank you
The defroster lamp and the ac problem are not related.
You can pull back the panel next to the left seat to access the defroster switch. I keep blowing fuses on mine. I can't get it to work. Still fiddling with it.
As far as the ac issue goes. Check the fuse first. The switch is located under the same panel of course. It's a tight fit under there. The switch may be disconnected.
I have some diagrams that may help. Shoot your email to me in a PM and I can send them to you.
Craig
Old Jan 22, 2020 | 02:21 PM
Elpica81's Avatar
Elpica81
Cruising
Hi Street Rat, my issue is everything was working before the boot replacement? as far as switch are you referring to a fuse? or an actual switch? also i am referring to the rear window defroster that the light stays on. My email is andres@pro-os.com
Thanks for your help!!
Old Jan 22, 2020 | 03:39 PM
Street Rat's Avatar
Street Rat
The defroster switch has a fuse and a circuit breaker in the fuse box. When it is getting power to the grid the light is on.
The ac switch in the console may have had the connector knocked off. Very easy to do when fooling with the trim plate.
I'll send you some diagrams to look over.
Documents sent.
Old Jan 22, 2020 | 03:43 PM
Elpica81's Avatar
Elpica81
Cruising
perfect thank you Sr.
Old Jan 22, 2020 | 03:44 PM
Street Rat's Avatar
Street Rat
Your welcome!
Good luck.
Old Jan 22, 2020 | 03:47 PM
Elpica81's Avatar
Elpica81
Cruising
Thank you Sr.
Old Jan 23, 2020 | 09:20 AM
Street Rat's Avatar
Street Rat
Thank you Sr.
You are welcome.
Let us know what you found.
Old Jan 23, 2020 | 10:09 AM
Elpica81's Avatar
Elpica81
Cruising
I will thanks agian
To defroster switch
