Emergency hood release
Old Jan 30, 2020 | 08:47 PM
oldgto's Avatar
oldgto
Default Emergency hood release
I thought I`d share one of the improvements I made to my 71 coupe. After buying a couple poor quality hood release cables, and having the handles pull right off, I decided to add an emergency release cable. Using an old piece of brake line for tubing, and a couple small straps, I ran a cable in the tube, up to the release lever. On the bottom end the cable is fastened to a ring that will be used as the pull point. It can be reached through the holes in the lower valance, reaching up behind the headlights. Grab the ring & give it a little tug, and the hood pops right open.
Old Jan 30, 2020 | 10:06 PM
ZAKsPop's Avatar
ZAKsPop
I like that. Adding to my to-do list.
Old Jan 30, 2020 | 10:40 PM
CraigH's Avatar
CraigH
great idea. I may look to add that to my list as well
Old Jan 31, 2020 | 11:47 AM
Jeff k's Avatar
Jeff k
Nicely done 👍
Old Jan 31, 2020 | 02:53 PM
L-46man's Avatar
L-46man
Clever! I also made a tool 43 years ago that is still in my tool box for the early models and made one recently for the late models....(I have one of each)
Utilizing the emergency release points that Chevy was clever enough to provide originally. They are small enough to go into the rear compartment.
Not that I care about NCRS...but using the Chevy release points, you don't have to 'add' to the car.
Cheers.
Old Jan 31, 2020 | 03:39 PM
Greg's Avatar
Greg
Just another Corvette guy
Can you elaborate on this a bit please? Or share a pic?
Thanks, Greg
Old Jan 31, 2020 | 03:47 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Thanks, Greg
On a 70-72.....one can remove the drivers side vents and get to the release tang by reaching up through.......I have done it a few times on mine.
There are plastic knock plugs that are in the upper firewall that you can pop out and trip with a screwdriver.....but it is a funny angle....
To the OP.......that is an OUTSTANDING mod......you should sell these! Total out of the box thinking.......nice job.
Jebby
Old Jan 31, 2020 | 04:49 PM
L-46man's Avatar
L-46man
Jebby nailed it.....Chevy in their occasional wisdom made these two bail out points...unfortunately, I had to do BOTH early and late....hence the tool(s)
On the early ones they actually put a notch in the hood..so that was designed in.
On the 'long hood' units, they provided knock out plugs at the latches...they push inwards and to the side!
Always an interesting party trick at car shows....." Jeez I didn't know that"
Even the C-7's have a bailout when the battery dies and you can't open the totally electric doors/ hatch.
I am always reticent to describe fully, how to break into C-3's.....
Cheers Unkahal
Old Jan 31, 2020 | 07:41 PM
oldgto's Avatar
oldgto
Jebby
Thank you! With my luck, it would be at night, with no tools, far from home when it would break, and I`d need to get it open, LOL!
That`s why I wanted something I could reach, and use, without tools.
Old Jan 31, 2020 | 08:26 PM
Old Man in a C's Avatar
Old Man in a C
Nice job, a hell of a lot better than the piece of trash I bought from a vendor.
Old May 12, 2021 | 02:54 PM
kodpkd's Avatar
kodpkd
OLDGTO. The connection at the latch, I can get the L shaped piece. How did you connect the wire to the L at the latch? Is it a little squeeze on fitting?
Old May 12, 2021 | 05:01 PM
oldgto's Avatar
oldgto
Yes, it`s called a "cable stop".... slide it over the end of the cable & smash it down with a hammer.
There`s a small hole in the L bracket, and the cable stop is under there, but you can`t see it in the photo.
Old May 14, 2021 | 11:04 AM
kodpkd's Avatar
kodpkd
Call me copy cat. I used copper fuel line that was easy to bend. I just made a loop at end of the stainless cable.
Old May 14, 2021 | 02:08 PM
oldgto's Avatar
oldgto
Cool! Cheap & easy fix! After I pulled the handle off TWO "replacement" hood cables, I needed a back-up plan!
Old May 15, 2021 | 10:07 AM
kodpkd's Avatar
kodpkd
I also wanted to make sure my latches were aligned correctly so my hood wouldn't get stuck. I taped a piece of paper over the latch holes, put a bit of grease on the point of the latch cone, closed the hood just enough so the grease would make a mark on the paper. The lower cones were not even close to being in the center of the hood latch. It was easy to adjust them.
Old May 15, 2021 | 12:44 PM
carriljc's Avatar
carriljc
kodpkd
Do you need one on each side? I should put this on my to-do list. I might be more likely to this....than finding a pre-sheathed contraption.
Old May 15, 2021 | 02:33 PM
kodpkd's Avatar
kodpkd
This wire will just be a backup if the main hood release breaks or if the lever that the hood release is hooked to breaks. You could run a parallel wire from the left hood latch to the right latch as a backup if the original wire breaks. There might be a way to run a secondary wire to the right hood latch. These backup wires will help if the originals break, but wont help if the latch itself is stuck locked.
EDIT: Looking at the right latch, you could hook a cable to where the spring is attached and run it to the front of the hood just like the left side.
To Emergency hood release
