Driver Door Window Noise
Old Feb 13, 2020 | 10:08 PM
Inca32x's Avatar
Inca32x
Default Driver Door Window Noise
The power window on the driver door makes a loud ‘clunk’ when their is about 2-3 inches from disappearing into the door. Window fits well in the weather stripping but the clunk seems like it will lead to a real problem eventually. Any suggestions on what I should be looking for when door panel is removed and troubleshooting starts?
Old Feb 14, 2020 | 12:04 AM
NONN37's Avatar
NONN37
maybe a broken gear tooth in the regulator mechanism
Old Feb 14, 2020 | 04:39 PM
SwampeastMike's Avatar
SwampeastMike
If the window goes down significantly faster than it goes up the assist spring is broken. When that happens it stresses the motor and the regulator eventually ruining both.
To Driver Door Window Noise
