found this thread (i should have searched before)Quote:
Originally Posted by rvzioView Post
The base 350/300 has a 2 bolt main. Most folks have the original motors bored 30 over and while you at it put in 4 bolt mains..
Not in 69. The base 300 hp 350 in 1969 was a ZQ3 and not a L48. A ZQ3 is the code for the base engine and was a high compression (10.25:1) L48 and had 4 bolt mains. The lower CR/2 bolt L48 arrived in 1971. (note, there are many instances where people have discovered their L48 had 4 bolt mains from the factory - luck of the draw)
In 69 there were two 350's, the 300 hp ZQ3 and the 350 hp L46. The difference between them is essentially valve size, camshaft and pistons, so it is possible to upgrade a ZQ3 to a L46 spec. A SBC being a SBC you can also turn it into just about any engine spec you want.
Further..depending on how much of the car is lost to time....
Big block radiator?
Fan clutch?
Type of radiator..copper vs aluminum.
I know this is dumb (and its long gone) emission sticker.
I have a loose ZQ3 in my garage now. 4 bolt main and cast flat tops. Decent 186 double hump heads with small valves. Pretty much an L-48 with smaller combustion chamber heads.
The ZQ3 is the option code for base engine for 1969-1972. Then L48 was used as standard engine code for 1973-1980. "Z" codes denote packages, which may or may not include a particular engine. ZQ3 denoted the base Corvette with standard suspension, standard tires, standard engine
Suffix codes for a base engine in 1969
HY 350 Base 300 Rochester Q-jet & Manual Transmission
HZ 350 Base 300 Rochester Q-jet & Turbo Hydra-Matic
