74 power windows
Old Feb 24, 2020 | 04:04 PM
StingrayJ's Avatar
StingrayJ
3rd Gear
Default 74 power windows
My 74 has been in the garage for the last few months and driven occasionally, the last time I took it out neither power window worked. Where should I start before motor replacement since both stopped at the same time? Any help would be appreciated!
Old Feb 24, 2020 | 04:08 PM
SwampeastMike's Avatar
SwampeastMike
There should be a circuit breaker installed in the "PWR ACCY" slot of the fuse box. Remove it and check for continuity with a test light or ohmmeter.
Old Feb 24, 2020 | 04:18 PM
StingrayJ's Avatar
StingrayJ
3rd Gear
kinda thought that, bored at work and figured I’d ask on here
Old Feb 24, 2020 | 05:19 PM
SwampeastMike
Sorry. The circuit breaker from '68 - '74 isn't in the fuse box--it's on the firewall. I suggest you study this thread. If the breaker is OK make CERTAIN to check the fuse (in the box) mentioned before tearing DEEP into the center console to get to the power window relay!
Old Feb 24, 2020 | 05:26 PM
StingrayJ's Avatar
StingrayJ
3rd Gear
Old Feb 25, 2020 | 05:35 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Here is a step by step... http://repairs.willcoxcorvette.com/1...ire-schematic/
To 74 power windows
