TH350 filter?
Old Mar 29, 2020 | 10:47 AM
Novusuhu's Avatar
Novusuhu
Default TH350 filter?
Hey guys
Because of the current situation in Belgium (Covid19) I have to stay inside... So the only things I can do right now are playing drums, gaming and working on my 77 C3.
I already bought transmission fluid (dexron 3) and a new aluminum pan with drain plug and gasket for the th350. But it seems I also need a new filter...
I prefer Wix filters. With the added filters on the Summit website I still get 4 different results.
Are there more then one type of filter for the TH350?
Maybe there is a quality difference?
What filter do you guys prefer for the th350 (1977)?
I wish you all a good health!
Old Mar 29, 2020 | 11:49 AM
jackson's Avatar
jackson
If you're certain it's THM350 trans ... should be WIX 58894
58894 has the Better (Dacron) filter media (catches smaller debris)
the other "square" elements are more of a mesh strainer than a filter
58894 much cheaper at rockauto
Old Mar 29, 2020 | 02:04 PM
HeadsU.P.'s Avatar
HeadsU.P.
Does your new pan have extra capacity? If so, you will need a filter with a extension (spacer) to place the unit deeper into the pan. Maybe that's the extra part numbers you are seeing.
Old Mar 30, 2020 | 12:28 PM
jackson's Avatar
jackson
Maybe Not.
Filters don't come with an extension or spacer ... but some deeper pans sold as pan/spacer combo ... or buy spacer separately.
Old Mar 30, 2020 | 05:33 PM
Novusuhu's Avatar
Novusuhu
Same depth as the original.
Old Mar 30, 2020 | 07:27 PM
jackson's Avatar
jackson
(Quote of deleted comment removed)
(Edit)
Of course there are kits what include an extension ... But ... as above, Filters are not sold w/ an extension.
Last edited by vettebuyer6369; Mar 30, 2020 at 07:55 PM. Reason: Quote of name calling removed
Old Mar 30, 2020 | 08:26 PM
Motorvation's Avatar
Motorvation
https://www.summitracing.com/parts/tci-328500?rrec=true
Here’s the best replacement filter. The screen is brass, which makes it durable, cleanable and reusable. Check to see that it has the filter to valve body gasket. Be sure to notice the pan side of the filter is stamped “FRONT”. The filter will bolt/screw on backwards causing a leak that will ruin the trans. Use vasoline to hold the gasket to the VB if assembling under the car. And make line up dolls from 1/4-20 bolts for ease of install for both the filter and the pan.
Steve O.
Old Apr 28, 2020 | 07:26 PM
Novusuhu's Avatar
Novusuhu
Hey guys
Sorry for the... very late post.
But I finaly found a supplier in the Netherlands who sells the filter I need (the type you guys suggested)!
Coronacrisis yes... but he sells by post.
Thank you guys for the info!
To TH350 filter?
