Just a quicky ? for the group!!
Old Apr 6, 2020 | 02:36 PM
JavaJolt78's Avatar
JavaJolt78
Default Just a quicky ? for the group!!
Just had a complete set of Monroe N2/4321 shocks installed and would like to know what would be best tire pressure for just general short range trips and parades etc..My 78 never leaves Dover..
I forgot to that they the are Gas-Adjust type!!!!
javajolt78
Mike
Old Apr 6, 2020 | 02:41 PM
interpon's Avatar
interpon
javajolt78
Mike
I run 4 pounds above the placard on door for mine..(79) 20 front 24 rear is baseline....
Old Apr 6, 2020 | 03:23 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Whatever rides best for you. I run 32lbs all around.
Old Apr 6, 2020 | 04:35 PM
JavaJolt78's Avatar
JavaJolt78
Does tire size have any effect???
I run Firehawk-Indy500/P225/70R15/100S's?????
Old Apr 6, 2020 | 04:43 PM
MelWff's Avatar
MelWff
Your sticker calls for 20 front 26 rear but a would not run a modern radial below 30 PSI cold.
Old Apr 6, 2020 | 07:26 PM
Bikespace's Avatar
Bikespace
This, or even more. I think mine are at 35. Check the max rated pressure of the tire, and keep it below that.
Old Apr 7, 2020 | 07:30 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
When I was a kid at the shop we always put in 32 lbs. I would say that would be a great place to start and adjust as necessary. I run 30 lbs in my Firestone indys 235/55/17. I get up to speed then swing the wheel left and right when no one is around and feel if the car is responsive or sluggish and whether is feels like it slides into the turn or holds its weight. Its easier with taller side wall tires. I do it in my truck everytime I head to work to see if my tire pressure has changed. It works once you know your vehicle
Old Apr 7, 2020 | 10:33 AM
cv67's Avatar
cv67
St. Jude Donor '05
shocks have nothing to do with tire psi look on the sidewall.
usually run 32, no more than 34
Old Apr 8, 2020 | 07:56 PM
derekderek's Avatar
derekderek
Door sticker is for 40 year old tire design. Start a couple pounds below sidewall max psi and adjust from there.
Old Apr 8, 2020 | 09:29 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Corvettes don't have the extra weight in the rear to overheat the tires.
Smooth/soft ride = 30 psi front tires...…...…….26 psi rear tires (eliminates rear "bounce")
Firm ride/feel-the-road ride 32+ psi all 4 tires...….
(my rookie opinion)
Old Apr 9, 2020 | 02:31 AM
TCracingCA's Avatar
TCracingCA
I opened the thread expecting ****!
Old Apr 9, 2020 | 05:49 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
How Bloody disappointing!
Anyway. I run 255/60-15s. 32 psi for years and years. I've replaced a few sets of tires
Never got close to wearing one out.
Old Apr 9, 2020 | 08:02 AM
Elcransonator's Avatar
Elcransonator
Those are the tires on my '73. They are old/need to be replaced, do you know if those tires are still available? I've searched all the tire places (that I know of) and the interweb and I can't find any.
To Just a quicky ? for the group!!
