Electrical Gurus! - Door Ajar Light question
I highlighted in Yellow the connection you need to find. From that connection, the Lt Blue wire picks back up again and then goes into
your driver side door ajar switch. So I would first find this connector (I often look for a connector of the same size and look for the wire
colors like the one in the picture around it to be certain you have the right one.) and then you can find the fault. If you place the bulb back in the
socket and ground the Lt Blue on the other side of this connector the light should illuminate and you will eliminate the circuitry from the connector
back to the bulb. If it does not light, then you know it is from the bulb socket to (or in) the connector.
Don't get frustrated - chasing down these electrical issues takes patience and persistence.
The socket looks fine. The metal contacts are in place and clean. The bulb twists in place and is held tight.
I will continue to chase the gremlin later today.
As I mentioned, it was working fine, then just stopped (although I didn't notice exactly when).
Thanks for the input. Sometimes it really is something simple that is overlooked.
At the very least, at this point I've been successful at eliminating that which is not at fault. I'm closing in on it (thanks to all who have chimed in here with helpful advice!)
An option you have in troubleshooting the rear harness, instead of doing continuity checks down the wire, you can do the safety pin thing, i.e., ***** the wire before the connector, then after, etc. The only downside to this is, you need to keep turning the ign. sw. on/off, as i wouldn't recommend just keeping the ign. sw. on, just MAKE SURE you're stabbing/grounding the right wire!
Another thing: You mentioned you replaced the door ajar switches. If you soldered in new slip-in pins to the wires, make sure they're all the way in the nylon part, as they are somewhat slippery in the new switch, could slide back a bit, resulting in not grounding, somewhat unlikely, though, as both would need to fail.
The dwg. is pretty clear, when you enlarge it.
I found the rear part of the harness running under the sill plate. From there I believe that harness runs up the A-pillar. I'll have to see if I can get a glimpse of it up inside the pillar. Seems like an inaccessible place to locate a connector.
I'll continue my search later today. Thanks again
I appreciate all of the information you shared with me.
I chased the problem down to a loose wire at the connector. I had a hard time finding it. It was wrapped in black electrical tape and located on top of the fresh air duct.
It took a while, but this has been a learning experience. I now know when my door is ajar lol!
Thanks again guys! You rock!
The door ajar system I addressed a while back now, the cure was a new door switch, these screw in to the door jamb and access to the connections is through a small plate in the wheel well just in front of the rear wheels and held in place with self tappers, when you're finished make sure to seal them up when you replace them to keep the water out.
Graham
Graham
Yes, I have it resolved for now. My weak link was a connector under the dash where the Door ajar lamp wire was loose. It is currently working, but if the issue returns, that'll be the first place I look.
Graham
