A/C compressor questions
Old Apr 8, 2020 | 12:48 PM
Jim71Vette's Avatar
Jim71Vette
Default A/C compressor questions
Does anyone have any experience(good, bad, ugly) with the Pro6ten compressor? Setup for 134a.
Does the condenser need to be changed to a "parallel" type? If so, where can I source one that will use the OEM fittings and lines?
Does the POA need to be adjusted? Can I do this myself or just replace it?
Thanks, Jim
Old Apr 8, 2020 | 03:54 PM
L-46man's Avatar
L-46man
Your existing compressor (if it worked on F-12) will run fine with CFC-134A.
clean system thoroughly (you'll have to do this anyway
Change oil
Replace Receiver dryer, ANYWAY!
clean condensor
add appropriate schrader valves.
evacuate system
re-oil and recharge.
Old Apr 8, 2020 | 03:59 PM
CMD1's Avatar
CMD1
Pro Mechanic
This is a good article about a retro fit to R-134A in a '71 model.
https://www.corvette-restoration.com...-r12-to-r134a/
I have converted several with stock brass condensers with good results, but a more efficient model is always best.
Tight working space! Just time consuming, not too difficult.
Old Apr 8, 2020 | 04:06 PM
L-46man's Avatar
L-46man
The 'not working on CFC134a is a terrible 'myth'.
I have done this numerous times.
My little 'funny furrin car'...they said couldn't be done...with R-12 (F-12) it would run at 38° F on full...after the conversion and optimizing every component (the only replacement was the Receiver/dryer), it would run all day long at 27°=29°F....froze me OUT!
In AZ you don't care that the car is runnin' on 7 cylinders as long as the A/C works!
cheers.
Old Apr 8, 2020 | 06:43 PM
interpon's Avatar
interpon
cheers.
or calibrate thermometer ..damn close to my R12 38f
Old Apr 8, 2020 | 07:00 PM
L-46man's Avatar
L-46man
I got the joke! There is a little 'trick' I learned from a 'fellow old guy' here in AZ. See, originally I was from No.VT..."what do we care about A/C!"
The temperature probe/ bourdon pressure tube/bulb that opens/closes the orifice valve is calibrated at the factory (that builds them) to NEVER allow the system to run below 'say' 36-38° F....otherwise the evaporator core can freeze over in humid weather. I 'remoted' the temp probe about 18" away from the Evap core....NOW IT ROCKS! My little AUDI TT has Climatronic and you can't do that....so it sits at 40° F.....huge difference from the '78 Scirocco that I mentioned above. Especially in those first five minutes!
In AZ we just don't get the humidity enough to matter. Now, if I was in New Orleans...different story.
End of June in AZ = 120° @ 2-5% RH.!!!!!
All temps were with my trusty calibrated THERMOCOUPLE (type K/ yellow) Only Amateurs use thermometers! LOL
Be COOL and BE WELL!
Unkahal
Old Apr 8, 2020 | 07:58 PM
Jim71Vette's Avatar
Jim71Vette
The A6 I currently have is toast and is the 2nd or 3rd replacement. Before I replace it again I thought I would ask about the Pro6ten.
I already have a conversion kit(dryer, o-rings, etc ).
Sounds like I don't need a new condenser or POA.
Old Apr 9, 2020 | 01:40 AM
platinummaker's Avatar
platinummaker
Unkahal
Could you be kind enough to explain how you did that and if it decreased the temp. I’ve been wrestling with the factory system trying to make it more efficient. Would love for it to drop a few degrees.
Thanks much
Old Apr 9, 2020 | 09:07 AM
interpon's Avatar
interpon
if 'toast' is shrapnel... the entire system needs to be flushed..IMO
also I have heard from many on this forum do not waste time with rebuilds.. I went NAPA with warranty...they do require flush , etc.. its right in the warranty proof of buying...
To A/C compressor questions
