I know the servo cruise control cable is not available from any vendors. But wanted to know if anyone has found a solution for this issue? Maybe a custom made cable?? Thanks
Mike
You are correct, the C-C cable is a one year only and not being reproduced for the 1977 Corvette GM #460824.
Problem is the 77 cable length is 37-3/4".
You can look at something like this, but again the cable length is 36". Maybe there is a 38" kit out there?
GM Universal Throttle Cable Link: https://www.autozone.com/fuel-system...cable/536804_0
Let me know if you need other measurements.
