transmission
Old Apr 25, 2020 | 11:43 AM
planet-automobile's Avatar
planet-automobile
Default transmission
hello
on your corvettes, the flow of transmission fluid is like that?
thank you
Old Apr 25, 2020 | 12:00 PM
Mooser's Avatar
Mooser
Looks right, knowing the year always helps
TH400
https://www.corvetteforum.com/forums...e-routing.html
M
Old Apr 25, 2020 | 03:47 PM
HeadsU.P.'s Avatar
HeadsU.P.
Ya, I guess so. I had a hell of a time figuring which line flowed which way when I installed a trans cooler. The A.I.M. book was worthless on that detailed description.
I read somewhere that GM wanted the flow seemingly backwards. I recall the theory was that any air bubbles would dissipate at the top of the Rad. But I don't see how that could happen on a "closed" system.
On my trans cooler, fluid enters from the top, gravity flows down.
Old Apr 25, 2020 | 06:17 PM
bazza77's Avatar
bazza77
I traced the picture for the TH350 , the flow went into the bottom of the cooler , gives it a chance to push all the air out of the radiator cooler part I guess.
To transmission
