Distributors - Tach Drive - universal vs Corvette
Old Apr 29, 2020 | 10:00 PM
Mooser's Avatar
Mooser
Default Distributors - Tach Drive - universal vs Corvette
So I keep seeing some Distributors listing the tach drive as universal while others say Corvette and I've always wondered if there was actually any difference in them, like the angle of where the drive came out or something. Somehow I don't think there would be any difference but MSD calls it a corvette while DUI says Universal
Just curious if anyone's actually seen a difference or not
M
Old Apr 29, 2020 | 11:21 PM
jackson's Avatar
jackson
No diff ... MUCH prefer DUI quality, fit, form, function to msd
know nothing bout em but have ya seen these two ?
https://progressionignition.com/shop...ap-distributor
https://progressionignition.com/shop...ei-distributor
Old Apr 30, 2020 | 07:19 AM
69ttop502's Avatar
69ttop502
I could be wrong, but I believe the difference with MSD is the the Vette cable is square so you need to use the little adapter. No experience with other cable drive tachometers to confirm this though. This is the piece they say is needed for the Vette tach’s.
https://www.vividracing.com/-p-15164...oaAlSUEALw_wcB
Old Apr 30, 2020 | 08:22 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
I know on the MSD the tach drive is located in a different position. I had to mod the passenger side ignition box shield mount to get the fit where it needed to be to get the timing perfect.
Old Apr 30, 2020 | 09:18 AM
Mooser's Avatar
Mooser
Weird since MSD is the one who called it a "Corvette Tach drive" I wonder what a tang drive is...
M
Old Apr 30, 2020 | 09:20 AM
Mooser's Avatar
Mooser
I think the "universal" one is as well. I've got one of the cheapo Skip-White HEIs with the tach drive and the vac-advance would run into the ign shield on the BB
Thought maybe the MSD was a "Corvette" one because it was right, guess not
M
Old Apr 30, 2020 | 10:15 AM
jackson's Avatar
jackson
.An industryy standard (including GM) for cables' ends is 0.104" square (often round cable core simply compressed into a square cross-section)
OE C3's dist & tach And trans & speedo use 0.104" square drive.
Another standard is tang drive (there are several configurations; typically a round ferrule with one or two tangs protruding 90* from core).
IIRC, Mallory, Stewart Warner, Aircraft and Boats often use tang drives.
https://www.speedwaymotors.com/MSD-8...iABEgL1M_D_BwE
Old Apr 30, 2020 | 10:25 AM
Big2Bird's Avatar
Big2Bird
The MSD is a small cap, and the DUI is a large "coil in cap."
Old Apr 30, 2020 | 10:27 AM
Mooser's Avatar
Mooser
So that adapter must go from square drive cable to tang drive distributor?, wouldn't be needed on the MSD for a vette then I think
M
Old Apr 30, 2020 | 10:31 AM
Mooser's Avatar
Mooser
You figure their just calling it a Corvette tach drive because it has the smaller cap? Maybe fits better than an large cap? I don't think it would fit under the shielding though, looks tall, although I do like that style of wire connection over the points style I still think they are a lot taller and wouldn't fit under the sheilds.
M
Old Apr 30, 2020 | 11:06 AM
Big2Bird's Avatar
Big2Bird
M
I have seen the MSD under the shielding. It may need creative modification. If you do not care about AM radio interference, box up the shielding and save it.
The large cap will not. As for semantics, the only other tach drive dizzy I know of is early small T Birds, witch have their own set up.
Perhaps DUI just avoids the use of the word "Vette", which would require GM licensing.
The MSD unit requires their box, the HEI does not. Either way, original appearance is gone.
Old Apr 30, 2020 | 11:39 AM
Mooser's Avatar
Mooser
Original appearance has never been one of my strong points.
My points distributor needs rebuilding, the shaft is fairly loose. I stuffed a cheap ebay HEI unit in with all of the important pieces switched to "better" parts so it's really just a housing at this point running with a separate MSD box and depending on what day it is a coil in cap or separate coil.
For no particular reason other than being able to run the shielding again I was looking at options the other day (small cap hei without tach-drive + convert to a newer electronic tach or convert mine to electronic, small cap version with tach drive, find the parts to rebuild my points one) doesn't matter as they all come out pretty close to the same $$$
But anyway, that's when I saw the universal vs Corvette call out again and finally decided to ask
Maybe I'll just ignore it for another season (if we get a season this year...)
M
Old Apr 30, 2020 | 01:54 PM
jpatrick62's Avatar
jpatrick62
I'd be interested in finding a tach drive HEI distributor that can fit under a 75 radio shield. That will be my next project after I get my electrical harness fully fitted...
Old Apr 30, 2020 | 02:05 PM
Rescue Rogers
I went with the stock style distributor (before the MSD) and converted it over to a breakerless HEI system, It worked great until the bushing cracked that held the shaft down in the distributor. I had the MSD on the shelf so I tossed it in.
Old Apr 30, 2020 | 02:11 PM
Gordonm's Avatar
Gordonm
For all the money being spent on these tach drive distributors just convert your tach to electronic. The cable drives suck anyway. They are bouncy and when running through the gears and if your motor rpms quickly the tach in inaccurate. Go electronic!
Old Apr 30, 2020 | 03:17 PM
Mooser's Avatar
Mooser
Then I'll need a new distributor AND a new tach
M
Old Apr 30, 2020 | 07:56 PM
jackson's Avatar
jackson
M
No, it may be needed on MSD dist ... call MSD or whoever you're considering & ask what drive theirs has
adapter is required w/ msd 8572 and it comes with it
https://documents.holley.com/8572.pdf
Old Apr 30, 2020 | 09:46 PM
Mooser's Avatar
Mooser
Yes I see it now, so the "corvette" distributor needs an "adapter" to work with GM square cables
I'm not actually looking to change (again) right now, (pus can't warrant spending $700 on a distributor), really just wondering why some called it a universal and others called it Corvette tach drives
M
Old May 1, 2020 | 10:21 PM
jackson's Avatar
jackson
up until early 70s, most any US car/truck with an OE tach had a mechanical tach.... not just vettes.
To Distributors - Tach Drive - universal vs Corvette
