is my engine block original or a crate.
Old May 5, 2020 | 02:35 AM
1978_Vette's Avatar
1978_Vette
2nd Gear
Default is my engine block original or a crate.
I recently bought a 1978 corvette my first car and was told that it had a 383 crate engine. The engine casting number is 3970010, the internet tells me it’s a 1968-1979 sbc 350 block. Could this still be a crate or rebuilt engine bored to 383 from some where like summit racing?
Old May 5, 2020 | 02:44 AM
hunt4cleanair's Avatar
hunt4cleanair
The 3970010 number is the block casting number and it was used as you note but there are a number of other parts that would make it an assembly like pistons, cam carb, etc.. It would be helpful if there was an engine stamp, typically on engine pad. Look at the link to a summy of my 78 and its numbers and where to look for them.
http://www.hunt4cleanair.net/Articles/VIN%209041.pdf
Old May 5, 2020 | 03:26 AM
Bikespace's Avatar
Bikespace
I use this site for Corvette numbers.
http://corvettec3.ca/
If it has any marks on the engine stamp pad, but was not from a Corvette, you may be able to look them up here:
http://nastyz28.com/chevy-engine-code-stampings.php
A "crate engine" means a lot of different things, so it is entirely possible that the block is older than the car, stroked to 383, and still a crate engine. It may even be the original engine, rebuilt and stroked, and the PO used the wrong terminology.
Please post some photos!
Old May 5, 2020 | 07:46 AM
derekderek's Avatar
derekderek
Very few crate engines were built using new blocks. They are just another name for a semi-mass produced rebuild.
Old May 5, 2020 | 10:41 AM
jackson's Avatar
jackson
and Most of the above have been overbored forty thousandths
383" is typically a modified 350" ... bored for larger-diameter pistons and fitted with a longer-stroke crank
All crates in Chevy Performance line (fka GMPP) are entirely new including blocks & heads
Same for Edelbrock crates
https://edelbrock-files-v1.s3.amazon...e-Brochure.pdf
OP has already received good guidance on Identifying motor ... compare its numbers against references e.g.
http://www.camaros.org/pdf/LimeBook.pdf
Old Sep 1, 2020 | 06:59 PM
Greg's Avatar
Greg
Just another Corvette guy
Old Sep 10, 2020 | 11:07 AM
Little Mouse's Avatar
Little Mouse
Title and register the car in another state.
To is my engine block original or a crate.
