Summer storage solution
Old May 5, 2020 | 11:24 AM
Harvette's Avatar
Harvette
Default Summer storage solution
I live in S.C. Where it gets pretty hot in the summer. I will be headed to Michigan for 3 months this summer without our C3. It will be covered and garage kept. My question is, Does anyone have any ideas about putting something in the interior to keep the humidity down? I was thinking Damp-Rid which we use in our RV. But wondering if there is something else that people use. Thanks
Old May 5, 2020 | 12:19 PM
ralphspears's Avatar
ralphspears
Banned Scam/Spammer
Disconnect the battery ( fire hazard )
Old May 5, 2020 | 12:41 PM
HeadsU.P.'s Avatar
HeadsU.P.
Dollar Tree has oval shaped tubs that once you remove the top seal works almost as good as Damp-Rid. What I like is that the unit is spill proof so if its tipped over water does not come out. I put one on the front passenger side floor and one in the back.. In the spring there is almost two inches of water in the tub. And that's with a garaged car.
Other than that, like Ralph said, disconnect NEG side of Batt. Put a good cover over the car and you are good to go.
Myself, I like to release the hood and tension on the latch springs. Might want to put a Battery Tender on for the three months too.
Old May 5, 2020 | 12:56 PM
Roy W.'s Avatar
Roy W.
Disabled by request 8 JUN 2025
Make your last fill up with ethanol free gas and make sure it makes it in the carburetor. It will save a lot of problems later on.
Old May 5, 2020 | 10:31 PM
Dagious's Avatar
Dagious
If you want to encapsulate the car, look into the CarBag.
https://www.carbag.com/carjacket/
Used it over the winter, with large descant bags, car was bone dry in the spring
Old May 6, 2020 | 11:41 AM
mark79,80's Avatar
mark79,80
The best way, would be to air condition the garage. If you have a window that would accommodate an A/C unit, would be the most economical way.
We have a home in Englewood FL and go north for the summer. I leave the A/C on 80 degrees and put damp rid in all the closets. Upon returning in the fall, all the damp rid bags are full, even with the de-humidifying action from the A/C. So I believe damp rid bags placed in a car in your garage would become full in a short time.
Old May 6, 2020 | 03:50 PM
68/70Vette's Avatar
68/70Vette
Can't buy alcohol free gas here in So Cal. I buy alcohol free racing gas when I know the 68 is going to be setting for a while. Pretty pricey! I try to buy lead free so it's also compatible with the 08.
Old May 6, 2020 | 04:33 PM
TotalBS's Avatar
TotalBS
Cruising
Hey Mark79,80,
I see you are located in Ithaca but go to Englewood. Im in Elmira and go to Rotonda West.
Love it down there!
Brad
Old May 6, 2020 | 05:32 PM
mark79,80's Avatar
mark79,80
Originally Posted by TotalBS
Hey Mark79,80,
Love it down there!
Brad
I love it in Englewood. It is one of the best kept secrets, I hope people don’t find out how nice it is and over populate the area!
To Summer storage solution
