Muncie speedometer gear?
Old May 8, 2020 | 01:13 AM
70rs/ss396's Avatar
70rs/ss396
Default Muncie speedometer gear?
What color on the gear do I need for my muncie when I have 3.55 in the back?
255/60-15 tires in the back.
Old May 8, 2020 | 08:28 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
It depends on the drive gear inside the transmission, they had 6, 7, and 8 tooth gears if I remember correctly. You can pull the driven gear and look in the hole, If you mark is with a marker you can count the gears, they are long helical gears but you can do it. * is pretty common
this is good info
https://www.thegearbox.org/catalog/i...82/3697857.htm
.heres a calculator....you need your tire size toohttps://www.5speeds.com/calculators/SpeedoCalc.html
heres some good parts places
https://www.thegearbox.org/Muncie.html
https://www.5speeds.com/cart/index.p...tegory&path=33
Old May 8, 2020 | 01:35 PM
70rs/ss396's Avatar
70rs/ss396
Thank you, that calculator was very helpful 😃
Old May 8, 2020 | 03:49 PM
Rescue Rogers
No problem!!!
Old May 9, 2020 | 10:55 AM
kodpkd's Avatar
kodpkd
I assume you are trying to make your speedo correct. I had the same issue. I took the speedo gear out, counted the teeth. Then use the "Thegearbox" table to go smaller or larger on the gear to change the speedo. You have to stay with the same size range of your drive gear.. 1.84 or 1.76 OD, unless you want to take your trans apart. Some times the colors are not correct.
To Muncie speedometer gear?
