front end
Old May 11, 2020 | 07:38 PM
tstrpalo's Avatar
tstrpalo
7th Gear
Default front end
Does anybody the cost to remove and replace a front end clip on a 1969 Corvette?
Old May 11, 2020 | 07:53 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
My rookie guess would be:
$1,500 for an inexpensive clip/$3,000 for a quality-grade clip...…...add another $1,000-$2,000 for labor and material....add another $2,000 for painting.
Old May 11, 2020 | 08:00 PM
tstrpalo's Avatar
tstrpalo
7th Gear
Okay.... thanks....its time to get my car back on the road.
Old May 11, 2020 | 09:38 PM
derekderek's Avatar
derekderek
how bad is the nose that you need to replace it?
Old May 11, 2020 | 10:50 PM
tstrpalo's Avatar
tstrpalo
7th Gear
the nose is fine, but it is a 1975 front. I want to put a 1969 front on
Old May 12, 2020 | 04:55 AM
derekderek's Avatar
derekderek
the nose can be had for 1300 bucks these days. but the bumper, bumper guards, brackets, grilles, grille trim, grille mounts, turn signals, side markers, frame extensions, crossmember all add up to nearly that much again. and if you go back to the correct hood and wiper door an additional 1000 bucks. the way you said "time to get my car back on the road" implies that it needs more than the correct nose. i would start researching and collecting the needed nose parts while bringing the car back to life as a 69-75 frankenvette. you could spend 6k easy if paying someone to do the swap and have a car that needs everything below the hood and from the doors back. i am toying with converting a 75 to chrome. the alterations to the outline where the bumper attaches to the 73-up body are not all that major to make a reasonable version of a 68-72 grille mouth. doing the job so no one can tell it was a 75 is a bit more involved. and the 75 nose isn't all that valuable or hard to find, so butchering one isn't a cardinal sin. plus, you still need all the hardware anyway whether you install it to a 69 nose or the already installed 75 nose.
Old May 12, 2020 | 12:02 PM
tstrpalo's Avatar
tstrpalo
7th Gear
Okay, thanks for the information. I do have all of the pieces to convert it back to a 69 except screws, bolts, vacuum hoses and the unknown.
Old May 12, 2020 | 02:25 PM
derekderek's Avatar
derekderek
just no actual nose?
Old May 12, 2020 | 02:54 PM
tstrpalo's Avatar
tstrpalo
7th Gear
I have the nose also...I just need to find a shop to do the work
Old May 12, 2020 | 03:39 PM
AllC34Me's Avatar
AllC34Me
Senior Member
St. Jude Donor '10
I would think there were some modifications made to allow the 1975 nose to be mounted in the first place. There is a frame that the 75 mounts to called a front extension which isn't used on a 69 and the 75 extension doesn't have any mounting points for the 69 bumper extensions. If those changes are needed it will cost you more to have a shop make those corrections.
Just an fyi.
Good luck with your changes and best regards,
David Howard
Old May 13, 2020 | 08:40 PM
derekderek's Avatar
derekderek
i unbolted my 75 air tank-crossmember and the frame extensions, 71 crossmember and horseshoe all bolted right up.
Old May 14, 2020 | 08:23 AM
tstrpalo's Avatar
tstrpalo
7th Gear
I'm glad to hear that...thanks
To front end
