Early '69 Interlock Steering Caution Label
Old May 13, 2020 | 01:07 PM
KS69Coupe's Avatar
KS69Coupe
Default Early '69 Interlock Steering Caution Label
Good Afternoon CF,
Looking for some assistance in sourcing an Early 1969 Interlock Steering Column label that attaches to the left-hand side of the steering column. I've tried my usual sources but so far have only been able to locate the Late '69 Standard Steering Column interlock steering label that is white lettering on a clear background. What I need is the early '69 version that is printed on white paper with the words ATTENTION in bold red print at the top of the warning label and DO NOT in bold red lettering about half-way down the label. Photo attached of what I'm trying to source. The NCRS correct label looks to be roughly 2" x 3" in size, printed on white paper, peel-n-stick pressure sensitive style label.
As always, thank you in advance for the assistance.
Kevin
Early 1969 steering column label
Old May 13, 2020 | 05:36 PM
PJO's Avatar
PJO
Veteran: Marine Corps
A suggestion buy several of the typical replacement label without "ATTENTION" Then have a stamp made with the correct font and with red ink attempt to stamp it to the new label.
Old May 14, 2020 | 10:59 AM
KS69Coupe's Avatar
KS69Coupe
Good Morning PJO, Nice to hear from you. Hope you and your family are healthy.
Thanks for the suggestion. I could certainly make that work.
Follow-up question, any idea where to source the roughly 2" x 3" white paper label? I've tried Corvette Central, Willcox, and Zip with no luck. They all carry the later '69 steering column warning label which is white print on a clear plastic (peel-n-stick) background. Did they make a paper Interlocking Steering Warning Label for different year(s) that would work?
Thanks in advance,
Kevin
Old May 14, 2020 | 06:59 PM
PJO's Avatar
PJO
Kevin
Thank you for asking all is well here with my family. Hope all is well also with your family. Stay safe.
Old May 21, 2020 | 09:37 PM
jhudec's Avatar
jhudec
The early label is not reproduced as far as I can tell. I could also use one for a Sept 11 1968 built convertible.
Old Oct 9, 2025 | 09:38 AM
malicatasr's Avatar
malicatasr
Originally Posted by KS69Coupe
Good Afternoon CF,
Kevin
Were you ever able to source the early label or did you make one? I'm also looking and for an early 69 which is a unicorn.
Old Oct 9, 2025 | 10:57 AM
KS69Coupe's Avatar
KS69Coupe
I worked with Patrick Hulst at corvettestickers@gmail.com to reproduce this sticker. After some adjustment to the backing adhesive, he was able to dial this interlocking safety sticker in perfectly. I've had mine a couple of years now and it looks great.
Kevin
Old Oct 9, 2025 | 02:44 PM
corvgreg's Avatar
corvgreg
Emerging Vendor
Ive only seen one of these labels on an early tilt tele column, and if I remember correctly it was smaller and rectangular shaped on the side of the lock housing, not the tilt bowl.
__________________
Greg
Old Oct 10, 2025 | 06:39 PM
PHulst's Avatar
PHulst
I do have them if anyone is interested.
Old Oct 14, 2025 | 09:55 AM
malicatasr's Avatar
malicatasr
Thank you, I may take you up one one of them. My original was badly damaged. I was able to produce my own for now.
Old Oct 14, 2025 | 03:58 PM
corvgreg's Avatar
corvgreg
Emerging Vendor
What is the trim tag date of your car?
There are two different labels used, then in April 69 they changed to the plastic tilt bowl cover.
Old Oct 17, 2025 | 02:27 PM
malicatasr's Avatar
malicatasr
My build date is September 11, 1968 It's an early date 1969
Old Oct 17, 2025 | 03:32 PM
jhudec's Avatar
jhudec
Very interesting Malicatasr. I would love to hear more about your car as I also have a Sept 11 1968. It is an L46 Monza red convertible.
Joe
Old Oct 17, 2025 | 03:57 PM
Rowdy Rat's Avatar
Rowdy Rat
That’s a really nice reproduction Patrick, as usual!
Regards,
Stan Falenski
Old Oct 18, 2025 | 09:04 AM
malicatasr's Avatar
malicatasr
Joe
its a Can Am white convertible with a base 350 & turbo 400.
Currently it’s getting the paint and bodywork done.
check out my previous post
https://www.corvetteforum.com/forums...m_content=post
tell me about your red drop top
mike
QUOTE=jhudec;1609175472]Very interesting Malicatasr. I would love to hear more about your car as I also have a Sept 11 1968. It is an L46 Monza red convertible.
Joe[/QUOTE]
To Early '69 Interlock Steering Caution Label
