Thermostat housing question
Old May 16, 2020 | 08:29 PM
Jim71Vette's Avatar
Jim71Vette
Default Thermostat housing question
When I put my rebuilt 71 L48 on a run stand I used a thermo housing for a 79 (Dorman 9022009) without any temp sensor. For the break in I "Bubba'd" a tee fitting on the intake.
The cam break in went well(far as I know anyway)...fast forward 13-14 months and I'm preparing to get the engine off the run stand and into the car.
My heads don't have provisions for a temp sensor...hence the '79 thermo housing and planning on using my '71 temp sensor in the housing.
BUT now that I look at it...the '71 sensor looks too long and will hit the thermostat.
Does anyone know if this will work or do I need to use a '79 temp sensor?
Is there a better way??
Jim
Old May 16, 2020 | 08:49 PM
derekderek's Avatar
derekderek
i beleive wilcox turns down the correct sensor to 3/8ths pipe for the alum and other later model heads.
Old May 16, 2020 | 09:40 PM
Jim71Vette's Avatar
Jim71Vette
These are "double hump" heads that I put on about 40 years ago, no provision for a temp sensor. I think the best solution is to use the '79 thermo housing if my '71 temp sensor will fit.
Old May 16, 2020 | 09:56 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
No fitting provision on either side of the thermostat on the water crossover?
Jebby
Old May 16, 2020 | 11:43 PM
ntfday's Avatar
ntfday
Veteran: Marine Corps
How about on the intake manifold, it was there for years.
Old May 17, 2020 | 11:01 PM
Jim71Vette's Avatar
Jim71Vette
I'm using the stock intake and it has one bung for the heater hose on the right side. I bubba'd a tee fitting so I could have heater hose and temp sensor.
I want to put the temp sensor in the thermostat housing.
Old May 17, 2020 | 11:30 PM
ntfday's Avatar
ntfday
Will this work? https://www.ebay.com/itm/GM-Performa...cAAOSwRY1dqzl1
Old May 18, 2020 | 08:20 AM
Jim71Vette's Avatar
Jim71Vette
That is the type of thermo housing I'm using now, but no sensor used. My question is can the '71 temp sensor be used with it? The sensor looks like it will interfere with the thermostat.
Old May 18, 2020 | 08:24 AM
Big2Bird's Avatar
Big2Bird
Screw the sensor into the housing, slip a stat in there, and see if they touch.
Old May 18, 2020 | 09:42 AM
jeffwebley's Avatar
jeffwebley
Just my opinion but, I don't believe you will get an accurate temp reading by placing the temp gage probe in the T-stat housing.
With the probe there, your gage is going to read cold until the t-stat starts to open.
If your cooling system is up to par, the t-stat will be opening and closing in response to the coolant temp. It does this constantly.
If not, the engine will heat up to whatever temp the cooling system is able to maintain.
i know my vehicle stays at 175*, all the time.
The thermal switch that is normally mounted in a t-stat doesn't require full operating temp to do it's thing.
It may work but, I wouldn't count on it.
A better place would be in the manifold, since your heads don't have the provision for a sensor.
Good luck and I hope it works.
Jeff
Old May 19, 2020 | 10:52 AM
jackson's Avatar
jackson
There's 1/2" pipe thread on side ... Have machinist mill a relief for t'stat in top of casting ...
... this will raise filler and makes it much easier to fill/burp motor ... and sender will be Below t'stat.
https://www.moroso.com/filler-neck-m...-housing63423/
https://www.moroso.com/filler-neck-m...-housing63420/
Old May 19, 2020 | 11:11 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
These things really are the **** if you have room........you can fill the block up before it gets to the rad. You can also run front/back coolant balance hoses.....which are great for sustained high load cooling.
I don't have one because they are ugly.....but they do make a billet anodized one.....but you need their cap and screw in Rad hose fitting......
https://www.summitracing.com/parts/MOR-63421
Jebby
Old May 19, 2020 | 01:33 PM
jackson's Avatar
jackson
fugly or not ... both castings I listed have integral male rad hose fitting + holes for balance etc + hole for OP's sender
Old May 19, 2020 | 03:56 PM
Jim71Vette's Avatar
Jim71Vette
Default OMG WTF now...
I decided to try Big2Bird's suggestion and just screw in the sensor to see if it fits. When I removed the radiator hose.... I see this mess.
It looks and feels like a white grease... but what is it? I have no idea where it might have come from... the hose is not clogged and the radiator(aluminum) is clean.
After I did the cam break in, the engine has been covered on the run stand for the last 13-14 months.
Old May 19, 2020 | 04:19 PM
jackson's Avatar
jackson
Oil & Coolant Emulsion ?
Old May 19, 2020 | 08:23 PM
Jim71Vette's Avatar
Jim71Vette
Hmmmm... doesn't seem to be any oil in the radiator.
Old May 20, 2020 | 08:13 AM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
I wonder what the inside of the engine block looks like?
To Thermostat housing question
Old May 20, 2020 | 08:41 AM
jackson's Avatar
jackson
Did someone "grease" the Outlet's OD or ID of Hose End(s) ? ... to prevent hose from "bonding" to outlet ?
Old May 20, 2020 | 09:47 AM
resdoggie's Avatar
resdoggie
Royal Canadian Navy
Whatever that gunk is it requires further probing into the intake manifold at least.
Old May 20, 2020 | 12:27 PM
Jim71Vette's Avatar
Jim71Vette
I pulled the valve covers and all was clean. I will pull the housing and thermostat and see what is in the intake.
The hose is clean and the radiator looks clean from what can be seen by removing the cap.
I guess the head gaskets are likely the problem. Should I do a compression test first?
