Some wiring help
Old May 17, 2020 | 07:36 AM
Olduffer's Avatar
Olduffer
2nd Gear
Default Some wiring help
Hi all,
My son recently purchased a 79 L82, and I am helping him install a set of dakota digital V series gauges. The previous owner had some of the dash wiring really messed up, so we are trying to straighten it out.
I am having problems with a few items I hope someone can help me with.
1. I can't find any illustration of what function the center gauge connector wires are for. I have found the diagram for the speedo/tach connector and their specific functions, but I can only find diagrams that show just the colors of the wires, not the functions for the center.
2. For the new fuel gauge, I am assuming I hook the pink(ohm) wire into the dakota control box?
3. Tach hook up..Do I need to run wires from the tach,? I know the speed/tach dash connector has a yellow wire that is listed as tach signal wire, but I'm not sure if that is what I need to use.
So, for anyone with experience hooking up dakota's gauges, I would really like to Thank you in advance for any insight you can offer.
Old May 17, 2020 | 09:30 AM
ClothSeats's Avatar
ClothSeats
If you haven't already done so, check this thread: Wiring Diagrams
Papawana on that thread will send you wiring diagrams for your specific year of Corvette within one day.
Old May 17, 2020 | 09:39 AM
henrikse's Avatar
henrikse
According to schematic pink is the fuel gauge. I see white wire for tach on schematic. I have attached schematic
File Type: pdf
Old May 17, 2020 | 10:52 AM
Olduffer's Avatar
Olduffer
2nd Gear
Thanks Guys!
To Some wiring help
