Timing light recommendation
Old May 18, 2020 | 09:42 PM
Oldwino's Avatar
Oldwino
Default Timing light recommendation
I’m sure this has been covered before but I can’t find using search function
looking for a dial back timing light recommendation For use with an MSD controller. What do you guys use?
Old May 18, 2020 | 09:46 PM
radiotexas's Avatar
radiotexas
Got mine at O'Reilly. All digital and a simple button to make things move. It was a hundred dollar bill.
Old May 18, 2020 | 10:05 PM
Mooser's Avatar
Mooser
I've got an innova digital which is awesome but it's a little screwy with the MSD box. so I purchased a Basic self powered non-dial back light (my balancer is engraved)
Best bet is to find an old non-digital one from a yardsale
M
Old May 19, 2020 | 12:21 AM
jackson's Avatar
jackson
^^^^ THIS ^^^^
circa 1977 Sun analog; no dial back, clips to alternator & ground w/ inductance sp wire clamp-around. Chromed die-cast pot metal.
like this
https://www.ebay.com/p/1723132350?ii...yABEgIi9vD_BwE
Old May 19, 2020 | 04:59 AM
derekderek's Avatar
derekderek
HF stuff is pretty good. even their non-dial back light. but i don't trust their dial back version.
Old May 19, 2020 | 05:48 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
i have the innova and use it with my MSD. I dont have any issues
Old May 19, 2020 | 05:59 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Dial back delay lights can sometimes cause delay in an MSD module......I have seen up to 2 degrees. Use a regular strobe style for MSD or other boxes.....but you will need a tape or markings on the balancer.
I recently bought the Innova/Bosch O'reilley $100 bill light last year.....same one as stated above.......works awesome on anything else, shows RPM and has a damn metal clamp on it which all lights should have had 40 years ago......
I have an ancient Craftsman strobe with semi-melted clamp that I use for my own car......lol.
Jebby
Old May 19, 2020 | 08:45 AM
Elcransonator's Avatar
Elcransonator
I got the Innova 5568 dial back. It works great and has the extra lead that goes to the coil for the dwell reading.
Old May 19, 2020 | 09:47 AM
Rescue Rogers
Thanks, I have an old one and my balancer already has a built in tape. I’ll compare them
Old May 19, 2020 | 09:50 AM
Mooser's Avatar
Mooser
Mine (Innova) is moves around at idle about 1-2 degrees with the MSD and seems (?) to get better when I bring the RPM up but still around a degree off at 3000 compared to the basic light.
Both read exactly the same without the MSD box
M
Old May 19, 2020 | 08:40 PM
Oldwino's Avatar
Oldwino
Thanx guys...guess I’ll stick with my old Penske.
Old May 20, 2020 | 08:18 AM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
My Innova light shows questionable readings below 3000 rpm with the MSD ignition box. Above 3000 rpm the timing indicator is rock steady but there isn't any multi-spark discharge above 3000 rpm.
Old May 20, 2020 | 09:25 AM
Rescue Rogers
Is it the box or their bigger coils?
Old May 20, 2020 | 10:23 AM
Mooser's Avatar
Mooser
For me it was the box as last year I tried various combinations of coils trying to chase a different issue, stock GM coil, baster II, and an igniter coils didn't seem to change much
Worst part is some people seem to have luck with them, others don't and there's no real way of knowing. I wish it was out 45degrees or something so it was obvious not 3 and stay there for a little then go to 2 for a bit then back to 3 so you have no idea if it's right or not
M
Old May 20, 2020 | 10:42 AM
Rescue Rogers
Ya I need to dig up that old analog light....my dad may still have one.....probably not inductive though
To Timing light recommendation
