Rally wheel paint
Old May 25, 2020 | 11:55 AM
steve meltzer's Avatar
steve meltzer
Default Rally wheel paint
Other than CC, is there an OTC silver green paint for the rally wheels on my '69 'vette? thanx steve
Old May 25, 2020 | 12:01 PM
KenSny's Avatar
KenSny
I thought they were all painted Argent Silver.
Old May 25, 2020 | 02:57 PM
jhudec's Avatar
jhudec
Nobody sells the correct argent silver(green/blue)hue. Search archive here and you will find some posts for formulas, but I could
never really figure them out with the correct mixtures to amount to mix, Quart or Gallon etc.....
Old May 25, 2020 | 05:31 PM
62corvette's Avatar
62corvette
69-70 had a more greenish argent silver. 71-up a purer silver.
Old May 25, 2020 | 07:35 PM
PJO's Avatar
PJO
Veteran: Marine Corps
That is not totally true early 1971 production till around S/N 3000 were painted with the greenish paint.
Old May 25, 2020 | 08:22 PM
steve meltzer
that pretty much settles it: sl green tint. thanx. s
Old May 25, 2020 | 08:35 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
your local auto pant store should be able to mix any color you want in a rattle can
Old May 25, 2020 | 09:31 PM
steve meltzer
thanx, i didn't know that. s
Old May 27, 2020 | 08:45 AM
JBrooke825's Avatar
JBrooke825
2018 C3 of Year Finalist
I just got some at jegs. Ordered it on eBay but it came from Jegs.
its hard to tell there is green in it.
Old May 27, 2020 | 08:55 AM
derekderek's Avatar
derekderek
i bet they bought a semi-truck tanker full of silver paint and the manufacturer didn't clean out their tanks well enough after the last run of green. they looked at the color and said "****. we can only use this stuff on wheels!"
Old May 27, 2020 | 09:12 AM
VERYSOON's Avatar
VERYSOON
Lars can provide you with the exact mixing formula I believe.
VS
Old May 27, 2020 | 05:49 PM
JBrooke825's Avatar
JBrooke825
Could be.
Old May 27, 2020 | 11:38 PM
Mark G's Avatar
Mark G
If you're doing more than just touch-up, I would spray out of a spray gun, use catalyzed paint (vs spray can paint). It's tougher and resists wear and looks better longer. Yer always going to have dogs sneak over from wherever and pee on the wheels, even when you're not looking. You can knock down the shine a little by adding some flattening agent to the paint if you so desire. It probably makes more sense to ask the paint store to add some (if they will) just b/c the flattening agent is like $70 a qt nowadays. But a good product to have onhand if you do much paint work.
If you sandblast the wheels, consider using a self-etching primer (here you CAN use a spray can of self-etching) for better corrosion resistance. Or a good 2k primer.
To Rally wheel paint
