Barn find- started blown head gasket??
Old Jun 6, 2020 | 11:28 AM
gaboriar's Avatar
gaboriar
Originally Posted by l82vett
First off the pictures of the drain oil do not show just an accumulation of moisture from setting. Thats a lot of water mix. I still don't think your out of the woods yet. Keep a eye on the oil. You said the antifreeze was ok, Antifreeze and internal engine parts don't get along to well, the antifreeze repels oil causing lack of lubrication on the bearings. On that posting about the fuel filter, after running awhile more change out that small filter again,. And as stated about the fitting on the carb, NEVER put tape or sealant on a flare fitting, the threads don't seal the connection, the flare nut pressure does.
The car was in the back yard of the property with a tarp over it. No evidence of direct water infiltration as the engine compartment and components didnt show too much rust. I forgot to mention I found a missing intake manifold bolt. I replaced it. Not accessory hole, an actual manifold bolt was missing. The interior was like a fish tank. Saturated for years. Even the under caarriage had lots of white mold. I'm in the New England so we get -10 to 100 weather and always high humidity.
Old Jun 6, 2020 | 11:42 AM
derekderek's Avatar
derekderek
pull the kick panels and check the number two body mounts. Take a look at the sheet metal right below the outer corners of the windshield. Don't fall in love with this car until you're sure the underside is solid enough. There's a real good chance you're working on a parts hulk. https://www.corvetteforum.com/forums...orvette-6.html. go to post 107 shows you how to find all the bad stuff on these cars that you are going to find on that car.
Old Jun 6, 2020 | 11:51 AM
l82vett's Avatar
l82vett
The intake bolt could be your problem. Water circulates through the intake front and back of it, both sides into the heads. If either the front 2 bolts or back either side are loose water could seep past the paper gasket down into the lifter valley and down into the lower engine oil. That could be your water leak problem. No real way to tell if the gasket is leaking there. A pressure check will show loss but not a given point. Intake manifold gasket is easier to change than a head gasket but still a PIA.
Old Jun 6, 2020 | 12:23 PM
Tampa Jerry's Avatar
Tampa Jerry
You could also pull the plugs to see if one or more look very clean as a result of being cleaned with water while the engine was running. A very rusty plug will also point you in the direction of a blown head gasket, cracked head or a cracked block. Keep us posted. Jerry
Old Jun 7, 2020 | 09:09 AM
gaboriar's Avatar
gaboriar
none of the plugs showed rust or looked "clean". Just typical carbon build up. The missing bolt was 2nd from the back / passenger side. I'm thinking it was that missing bolt that allowed the moisture to get in. That's direct access.
Old Jun 7, 2020 | 09:17 AM
gaboriar's Avatar
gaboriar
Thanks- I'll check out the #2s and see. Hopefully I dont find out I'm dealing with a " #2 "
Old Jun 17, 2020 | 09:58 AM
gaboriar's Avatar
gaboriar
Well so far so good. Run her all the time.
Oil- perfect
AntiFr-perfect
Running temp- perfect
Smoke on start up- none
Smoke while running-none
Issue:
Running VERY lean. Cant throttle up unless I choke her. Backed off the mix screws 7 full turns (quadrajet)
Next up:
Quick carb clean
Spray some carb cleaner around the manifold to see if gasket needs replacing
Compression test
Leak down test
Old Jun 17, 2020 | 12:01 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Originally Posted by interpon
After being sure it rotates ....
and raise you to 400 quatloos
Suddenly I am in the mood for Baked potatoes......
Jebby
Old Jun 23, 2020 | 09:22 AM
gaboriar's Avatar
gaboriar
carb cleaner seemed to make a big difference. Still cant pop the throttle from idle but now I can steadily raise RPMs then whack the throttle.
Oil still looks perfect.
Old Jun 23, 2020 | 10:32 AM
derekderek's Avatar
derekderek
Accelerator pump.
Old Jun 23, 2020 | 11:09 AM
gaboriar's Avatar
gaboriar
Derek- sounds like the culprit. I just bought the rebuild kit. Should come with the pump cup. thanks
Old Jun 23, 2020 | 11:55 AM
Peterbuilt's Avatar
Peterbuilt
Default Hi and welcome!
Get a napa 2-4055 accelerator pump.
Get the napa roll over filter 23051 (short).
or 23052 (long).
Old Jun 23, 2020 | 11:57 AM
  #33
gaboriar's Avatar
gaboriar
found some rot / rust on the passenger side of the windshield frame. Not horrible.
Old Jun 23, 2020 | 11:58 AM
  #34
gaboriar's Avatar
gaboriar
in addition to the rebuild kit?
Old Jun 23, 2020 | 12:04 PM
  #35
gaboriar's Avatar
gaboriar
or 23052 (long).
Says that pump doesnt match. Wont the carb rebuild kit come with a new cup?
The filter is just the incarb fuel filter? I replaced it.
Old Jun 23, 2020 | 12:39 PM
  #36
derekderek's Avatar
derekderek
kit will come with pump piston-diaphragm-cup-whatever it is called... is this windshield rot under the windshield? is windshield out? what do body mounts look like? cuz that matters more than the carb.
Old Jun 23, 2020 | 12:48 PM
  #37
gaboriar's Avatar
gaboriar
Under the weather stripping between the interior panel. You got me nervous now. Going to pull the kicker. Had a problem getting the sill plates out. Screws are rusted.
To Barn find- started blown head gasket??
Old Jun 23, 2020 | 01:06 PM
  #38
sjhanc's Avatar
sjhanc
So you did find the problem?
Old Jun 23, 2020 | 01:12 PM
  #39
gaboriar's Avatar
gaboriar
which problem? The running lean issue is probably due to the carb. Will rebuild. If that solves it then I'll assume for now the head gasket and intake mani gasket are Ok.
Old Jun 23, 2020 | 01:14 PM
  #40
gaboriar's Avatar
gaboriar
derek,
Well its not pristine thats for sure. Not horrific either. Lots of surface rust.
