Oil pressure adapter
Old Jun 5, 2020 | 04:08 PM
C3ForLife1968's Avatar
C3ForLife1968
Default Oil pressure adapter
Can anyone tell me what treads this adapter has? What are the dimetions? Thanks
Old Jun 5, 2020 | 06:20 PM
TimAT's Avatar
TimAT
1/8 NPT on the block side. 1/8 compression on the other. Should be available at the big box lumberyard, OR your local auto parts store. Take a close look at the compression side- some GM used a slightly different style of compression fitting and they are NOT interchangeable. If the ferrule on your existing line is cone shaped it's the one GM used. If it's a round looking ball, then it's a commercial fitting.
Old Jun 5, 2020 | 06:42 PM
loup68's Avatar
loup68
Army
The cone shaped ferrule will not rotate when you tighten the fitting, cutting into the plastic line. Also the cone fittings have course threads and need a special compatible nut.
Some fittings have a captive ferrule that is locked into the nut and these also will not cut the line. Hope this helps. Lou.
To Oil pressure adapter
