Rear Differential Seal
Old Jun 8, 2020 | 01:00 PM
newbie2vette's Avatar
newbie2vette
Default Rear Differential Seal
I am helping a friend with his first corvette, I found a 1973 with 61k Original miles, so original it still has all the spark advance vacuum lines installed. Anyway, I started to replace all the fluids to have a baseline. I change the rear differential, added new oil until it started to drip out then plug it back up. Several days later, the rear diff seal started to leak. If I overfilled this, will the extra diff oil be forced out of the seal? In the event I have to replace the seal. Does anyone know the size of the nut on the pinion? Never done this on a corvette.
Old Jun 8, 2020 | 03:25 PM
BKbroiler's Avatar
BKbroiler
If the differential was level when you filled it, you can't possibly have over filled it.
Old Jun 9, 2020 | 01:31 PM
MelWff's Avatar
MelWff
what fluid did you fill it with, brand, type and viscosity?
Old Jun 9, 2020 | 01:40 PM
joewill's Avatar
joewill
how did you drain the old oil out?
To Rear Differential Seal
