1977 Corvette with Hedman Headers engine bay hot
You may want to switch to a over-the valvecover looms.
Click on my profile, then see all photo albums, my engine build to see the insulators. They are a little pricey for eight. They come way too long. So I cut mine in half and they work perfectly. (order 4)
Next: Header Wraps. Not a big fan of the ugly ****. If you wrap new headers, it will void the warranty if the header company sees its been on there. Wraps do work well in certain situations.
But in my opinion, they have no place on a C3. They have a notorious habit of containing moisture after shutting off the engine. Moisture = Rust. No Thanks.
Next: Those header gaskets made of metal (aluminum-copper) will do that. No harm, no foul. As long as you have a good seal, at each port, what the gasket does between ports is irrelevant. Using a box-end wrench, just snug the header bolts. Don't use a socket / ratchet, torque wrench. Just snug 'em good with a box-end. Work from the center out. Good to go!
Click on my profile, then photo album, engine build to see the insulators. They are a little pricey for eight. They come way too long. So I cut mine on half and they work perfectly. (order 4)
If you have very high underhood temps, that could indicate that your timing is retarded. After I tweaked my timing a bit, the sidepipes are no longer scorching hot (I'll keep the side shields on, though).
The boots or sock insulators on mine, I believe are Moroso. They come in sets of four and in different colors. There is a steel ring inside the insulator that slips over the plug boot. You can discard that ring on 90* boots.
Yes, one plug wire still to swap out!
Wrap on headers to protect spark plug wires
Wrap on headers to protect spark plug wires.
Secondly, factory C3 Corvette plugs wires route under the exhaust, not over it. Been that way from day one without problems. The mere fact that plug wires are close to a manifold does not mean you have a problem, unless the wires are melting. Again, factory wires run under and very near factory cast iron manifolds,.....and always have been. Obviously, given the location of the plugs relative to the exhaust, there is no choice.
So my point is twofold. One,......headers are probably not the problem with what you are calling high heat. Heat comes from the engine. Secondly, plug wires are designed and manufactured to live very near high exhaust temperature. All this aftermarket fixes like heat shields and boots are solutions looking for problems. Sure, they work, but they are not required. I see one picture of heat shield on the steering box, and the exhaust is two inches away!!!! My stainless header is 1/8 inch away, and I see no issue at all.....no degradation in steering, no leaking grease, nothing. Maybe my steering box will fail sooner than one that has less heat exposure,....but I will bet it doesn't....and frankly, given the little driving most Corvette owners do, its another solution looking for a problem. A steering box is made of steel casting, with a few steel gears and bearings, and has hi temp grease in it.....prove to me that exhaust heat is going to hurt something.
Sorry if I don't tow the typical line on this subject, but my experience with stainless headers on a pumped up 350 in a C3 Corvette has proven there is no issue. More gimmicks by aftermarket companies to fix problems that don't exist in most situations., paid for by paranoid people who worry about things that others have long ago designed away.
Depending on sparkplug length, angle of plug in the cyl head, design of headers, diameter of header pipe, type of plug wire boots and material, a problem does exist.
I have seen plug wire boot touching the header due to poor planning, poor design.
The solution is of course to protect the plug boot no matter if its a straight boot or 90* boot. The problem does exist and its no gimmick to place an insulator between the plug boot and the source of extreme heat.
The pic is showing one of the protective boots I had fitted previously.
Spark plug cap protective boot
HEATSHIELD BUILDERS KIT PROTECTION SLEEVE 5/8" X 600MM
