Need help testing 69 fuel gauge / sending unit
Old Jun 26, 2020 | 10:56 AM
fazang's Avatar
fazang
Default Need help testing 69 fuel gauge / sending unit
Hi, i tried watching willcox vid and then perform the tests, not sure where to go from here.
My fuel gauge reads at 3 o'clock when i start the car, and sometimes reads correct while driving, those are the symptoms. Currently tank is full of gas.
Willcox instructions said:
Next ground the ohm wire and the gauge should read empty "E".
With the key ON mine does but want someone to look at pic to verify i "grounded" the
wire properly.
https://photos.app.goo.gl/7nwGF4dh38DVWyZFA
with the Ohm wire removed and the key ON the gauge should read past full and horizontal, like 3 o'clock.
Mine does that too.
BTW i had the ground terminal for the sending unit plugged in, was that correct ?
If these 2 tests were performed correctly, i think it means gauge in dash is fine, and the ohm wire from tank to gauge in car is fine.
So now i am stumped why the gauge likes to read 3 o'clock 90% of the time ?
thanks for any help.
-ALF out...
Old Jun 26, 2020 | 11:05 AM
Tiger Joe's Avatar
Tiger Joe
Sounds like you did the tests correct. Probably a bad sending unit
Old Jun 26, 2020 | 11:17 AM
fazang's Avatar
fazang
can i replace the sending unit from under the car or does the tank have to come out ?
thanks
-ALF out...
Old Jun 26, 2020 | 11:25 AM
fazang's Avatar
fazang
I finally found this and i think i have a bad sending unit like you said.
my multimeter reads 1. when i put terminals on sending unit ohm connector and ground.
http://repairs.willcoxcorvette.com/w...it-testing.pdf
thanks.
Old Jun 26, 2020 | 11:29 AM
Tiger Joe's Avatar
Tiger Joe
Yes you can change it from under
Old Jun 26, 2020 | 01:34 PM
MelWff's Avatar
MelWff
You did the test with a full tank of gas. Do the test with 1/2 tank and see if you get same results to confirm bad sender.
When you have 1/2 tank, turn on instrument lights, place key in run position, open tank and reach in and pull float up while watching gauge to see if it moves.
Old Jun 26, 2020 | 02:39 PM
fazang's Avatar
fazang
I just buttoned everything back up, so will wait til 1/2 tank, thanks.
trying to get rear high enough so can do this test, but my jack and a 2X4 may not be tall enough to get master cylinder level... :-(
Old Jun 27, 2020 | 12:46 AM
68/70Vette's Avatar
68/70Vette
Take off the gas cap, stick your hand down into the fuel tank, grab the gasoline float and pull it up. The gas gauge should read full. Push the float all the way down, the gas gauge should read emply. The "sender" is basically a wire wound reostat with the resistance reading determined by the float position. As you move the float up and down, the gas gauge should move up and down smoothly. Have someone siti the car to watch the gas gauge move.
The fuel tank will have gasoline and air in it, no smoking!
To Need help testing 69 fuel gauge / sending unit
