Electrician needed
Old Jul 5, 2020 | 09:24 PM
bobby70's Avatar
bobby70
Default Electrician needed
Hi every one big problem 1970 small blocks I removed my steering column great time to check things out under the dash so my wire harness is only a few years old and checking the fuses I saw that the whole right side has no power.started taking things off.no luck.takeing the steering column out would this have any thing to do with this.thanks for your help.if I take the fuse block apart can I use something to clean it and what kind of grease do you call it thanks again.
Old Jul 5, 2020 | 11:04 PM
Bikespace's Avatar
Bikespace
Dielectric grease. Non-conductive silicone lubricant.
Old Jul 6, 2020 | 08:45 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Theres a spray for electrical parts cleaning as well. They may carry it at an autoparts store. I got mine at a small electrical repair place. Its very strong and eveaporates fast. Dont get it on paint or plastic that you like
Old Jul 6, 2020 | 08:58 AM
derekderek's Avatar
derekderek
you could have inadvertently unhooked a ground. did the right side stuff work before you removed the column?
Old Jul 6, 2020 | 02:28 PM
bobby70's Avatar
bobby70
Yes it worked fine but what made me check the fuse block my radio was shutting on and off
Old Jul 6, 2020 | 10:08 PM
bobby70's Avatar
bobby70
if I have a bad fuse block could it be the engine wire harness
Old Jul 7, 2020 | 04:01 PM
derekderek's Avatar
derekderek
the radio can get intermittent ground thru the antenna. it could be the harness. it could also be 1 missing ground, or 3 or 4 .
To Electrician needed
