'81 front clip removal
Old Jul 10, 2020 | 08:00 AM
Maddan's Avatar
Maddan
Default '81 front clip removal
Was wondering if anyone could give some tips on how to remove my front clip. At some point one of the previous owners has removed the front bumper assembly, causing it to start to sag and come apart on the passenger side. thought it might be a good idea to remove the front clip, reinstall the front bumper, and freshen up the engine while I have easy access.
Thanks, Dan
Old Jul 10, 2020 | 08:41 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
My advice is never to remove a factory installed clip unless absolutely necessary. You should be able to make bumper repairs without having to remove the clip. Post pics of the bumper problem.
Old Jul 10, 2020 | 11:49 AM
derekderek's Avatar
derekderek
Bumper has nothing to do with sag. The headlight mount bars are coming loose from the hood surround. Probly getting diadonal cracks right in the front corners of the hood surround. Get the bars reattached and you may need a little Bubbaesque bracing to get the hood surround back where it belongs. Also is the hood above the hood surround?
Old Jul 10, 2020 | 04:15 PM
Mark G's Avatar
Mark G
Pics?
If you're wondering how to un-join panels, I used a heat gun and that worked best for me. That's what a lot of guys use for panel removal.
Old Jul 10, 2020 | 07:53 PM
Maddan's Avatar
Maddan
OK, my car no longer has the front bumper assembly/nose support in the car... so there is absolutely nothing holding up the front clip except the glue on the fenders...
Like I said before, whoever owned it before thought they were going to lighten it up by removing the front bumper assembly...
Old Jul 10, 2020 | 08:00 PM
Maddan's Avatar
Maddan
Thank you mike, nose is hanging low with absolutely nothing but the epoxy at the back of the fenders holding it up...
Old Jul 10, 2020 | 10:21 PM
MattoonVette's Avatar
MattoonVette
Living the Vette life....
Are the inner fenders not bolted to the radiator core support? There are 3 bolts on each side of the inner fenders that bolt to the radiator core. The very bottom bolt on each side should also be bolted through the frame.
Old Jul 11, 2020 | 06:28 AM
Maddan's Avatar
Maddan
Thank you Mattoon, I will look when it gets light out.
Old Jul 11, 2020 | 09:01 AM
Maddan's Avatar
Maddan
Okay, my radiator support is not bolted to the frame. It looks to be about 4" ahead of the frame horns. I am guessing that it probably actually bolts to the bumper brackets?.
Old Jul 11, 2020 | 10:56 AM
MattoonVette
Yes the radiator support does bolt to the front bumper support and the bumper support bolts to the main frame. When they removed the bumper support, they removed any support the entire front clip and radiator had. You said it right, sounds like only support is where the front clip is glued to the firewall/body area. Yikes. This is what the front bumper support should look like.
Old Jul 11, 2020 | 03:14 PM
Maddan's Avatar
Maddan
I do have a correct bumper support and bumper assembly, there is an approx. 1/2" gap at the top of the passenger fender where it meets the door. I was wondering if it would be viable to finish removing the clip, do my engine mods, and installing the replacement bumper assy., then reinstalling the clip...
Old Jul 11, 2020 | 04:40 PM
MattoonVette
There are two areas on each side of the firewall where the fenders are glued on and then also along the hood ledge at the top of the firewall. How loose is the clip now? It would be most helpful if you could post some pictures.
Old Jul 11, 2020 | 06:27 PM
derekderek's Avatar
derekderek
ok, the bumper bracket is also the frame extensions. 68-72 had one on each side. 73 on up had a u-shaped piece that was also the headlight vacuum storage tank. yours is just frame extensions and bumper mount. the 75 to 79 is the cheapest and easiest to find. leave the clip on the car. get a bumper-support-frame extension. get the nose back up where it belongs. that glue holds the fenders in, not the headlights, etc up. once the nose is properly supported and adjusted, you can reattach the strips that popped loose. they will line themselves up as the door gaps settle back in.
Old Jul 11, 2020 | 06:45 PM
MattoonVette
The 80-82 bumper support is specific to those those years. Not sure if the earlier years will work without some type of modifications. I think the big thing is is to get the bumper support back on the car. He stated he does have the correct one for the 80-82 years.
I am betting it will be a slow process to get the front clip raised back up to where it should be and so it aligns correctly. That is what I would try first before removing it.
if you have the radiator core support in it, I would put a jack in the middle of it and SLOWLY raise it up a little each day. DON’ T try to raise it all at once. I am talking about taking days to slowly reverse what has been done. Even then it still may crack or break something.
Oh and there is a small rubber mount that goes between the front of the clip and the bumper support. Make sure you have it too.
Old Jul 11, 2020 | 08:44 PM
derekderek's Avatar
derekderek
put the bumper support back in. loosely bolted to the frame. attach the rad support to it. get a jack under the bumper support and start adjusting...
Old Jul 12, 2020 | 06:18 PM
Maddan's Avatar
Maddan
The small rubber mount is not available new, or repop, I actually found a decent used on this website
Old Jul 12, 2020 | 06:20 PM
Maddan's Avatar
Maddan
Thank you to all who have replied to my thread, all were helpful.
Old Jul 12, 2020 | 07:58 PM
MattoonVette
Here you go if you want it new.
https://corvetteparts.com/item/mount...ount-1980-1982
  1. Product Information
1980 - 1982 Corvette
Mount, front frame extension to upper hood surround mount
  • Part Number: 333911
  • Reproduction: This part is made as close to OEM specifications as possible.
  • Replacement for OEM/GM Number: 3842913, 3842914
  • Selling Unit: assembly
↓ Jump to Full Product Description
Your Price:
$15.95 /assembly
Availability:This product is in stock.
To '81 front clip removal
