*HELP* 77L48 stalling on stop.
Old Jul 24, 2020 | 01:23 AM
77L48's Avatar
77L48
Default *HELP* 77L48 stalling on stop.
I have a 77 L48.
auto
Recently did a full tune up, new rear shocks, rebuilt carb, new slave arm and checked vac hoses.
The problem my mechanic can find... idles great drives great but when it's warm and I come to a stop (highway ramps, lights, pulling in my driveway..) it loses power. No power steering, gauges go dead, and it wont start until 10-30 minutes later. (Rarely, will start right back up)
any ideas? It's driving me nuts!! My mechanic says she runs like a dream, but for me.. coming to a stop is a nightmare.
*often it has trouble starting as well, when it's warm.
However, occasionally it starts and stops without issue...
WHAT GIVES!?
Old Jul 24, 2020 | 06:42 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
what is the start problem, no crank or does it just keep spinning over. Could be heat soak of the starter, could be a bad coil, could be a vapor lock or boiling issue with the carb. Usually the carb heat issues take a bit of sitting to absorb into the carb and happen so if it stalls and wont immediately restart then I would lean toward a choke issue. Did this happen before th tune up? if not then I would look at the choke and idle set screws. The car could be tuned with the car cold before the choke was fully open so that it starts and runs good for the first 10 minutes then it wont idle after that. Just turn up the idle set screw there. It could also be stalling because it is flooding, the jets could be sticking insed the carb. YOu can drive it around your neighborhood so its close to home and if it stalls, just pull the carb and look inside the carb and see if the fuel is seeping into the throat
Old Jul 24, 2020 | 08:18 AM
HeadsU.P.'s Avatar
HeadsU.P.
"Gauges Go Dead"
This indicates an electrical issue, possibly a poor ground cable connection due to heat & corrosion.
Should be four places that need to be removed, wire brushed, reconnected.
Battery GRD post.
Battery GRD cable at rear frame.
GRD strap near starter to block.
GRD strap from block to frame.
Old Jul 24, 2020 | 08:37 AM
KenSny's Avatar
KenSny
I agree.
The "Gauges go dead" is a pardon the pun, "dead giveaway" that it is not a carb issue, nor an engine issue, but an electrical issue.
And why does it take 20-30 minutes to restart - heat soak maybe?
Only dies when warm - again something electrical and heat related?
Old Jul 24, 2020 | 10:27 AM
77L48's Avatar
77L48
Originally Posted by KenSny
I agree.
Within 2 minutes it starts sometimes... usually takes 10 but can sometimes have me waiting on the road side for 30.
Old Jul 24, 2020 | 10:32 AM
KenSny's Avatar
KenSny
Your statement from opening post "No power steering, gauges go dead, and it wont start until 10-30 minutes later. (Rarely, will start right back up)".
Old Jul 24, 2020 | 10:33 AM
77L48's Avatar
77L48
It was running OK before the tune-up. I just bought it however (1st corvette and despite everything, I LOVE IT. It's a dream car). He has taken 3 looks at my carb system and tuned it a few times to address the issue, to no avail. As for the turnover: there was crank, but no catch. I can sometimes see the RPM gauge move a bit, but it doesn't fire up. After I let her sit, she fires up.
Old Jul 24, 2020 | 10:53 AM
77L48's Avatar
77L48
rarely, but not never
Old Jul 24, 2020 | 11:15 AM
69 LT1's Avatar
69 LT1
Is it really loosing power or has it actually cut out and your still rolling.
Old Jul 24, 2020 | 12:28 PM
Rescue Rogers
I didn’t see the gauges go dead part
. If it looses power and it’s truly random, try a battery test... It could be a coincidence as to the relation with the tune up. If you power to the whole car it could be a bad weld in the cells. When this happened to me with a Diehard battery back in 89. It was explained to me that the way they make their batteries was they put the cells in the case, fill with fluid, cap it then run high voltage through it to weld the plates together. If one of those welds cracks the battery just dies, then it can reconnect randomly and show no problems when it’s checked. They could be made differently but the symptoms are the same. Swapping the battery solved mine, but expensive just to throw ina new one.... I would check the battery connections at the starter, the horn relay, To eliminate those as issues then swap in a known good battery as a test or try and get yours load tested. Either that one the ignition switch is wacky but I doubt it
Old Jul 24, 2020 | 01:14 PM
77L48's Avatar
77L48
It cuts out and I roll. Provided I have any speed. Last night it cut out as I was turning into my driveway. Thankfully, I had enough speed to just fit it in. Usually, it cuts out as I come to a complete stop.
As for the battery... it has been tested and it is at 100%. CAA/AAA came out and tested the battery and couldn't find any deficiencies.
Old Jul 24, 2020 | 02:19 PM
69 LT1's Avatar
69 LT1
Is it the same carburetor rebuilt.
if so what was wrong with it.
what type is it.
if your willing to repeat the problem,
as soon as it cuts out pop the hood and check if your getting fuel to the carb.
Old Jul 24, 2020 | 02:29 PM
KenSny's Avatar
KenSny
So we're back to saying that the carb causes all the gauges to loose power? I've never even heard of that happening.
I'm wondering if maybe there is a short in brake light system. Comes to a stop, car dies.
Who knows? But, my money is still on electrical.
Old Jul 24, 2020 | 02:48 PM
69 LT1's Avatar
69 LT1
so when your cruising and your car dies / cuts out what happens.
Old Jul 24, 2020 | 02:49 PM
77L48's Avatar
77L48
what type is it.
It is the original quadrajet, rebuilt.
It was leaking gas onto the top of the engine.
I noticed it started to eat the paint.
I'm getting gas to the carburetor.
It's happened a few times and I've noticed it gets gas into the right places
Old Jul 24, 2020 | 02:51 PM
77L48's Avatar
77L48
There's a guy on my street that works on classics. I'm going to see him tonight. Will most definitely mention the electrical as a solution. I know little about cars so I very much appreciate yours and everyone's input.
Old Jul 24, 2020 | 02:56 PM
77L48's Avatar
77L48
When my car shuts down:
GEN light comes on
Loss of all power (steering/lights/gauges), as if I've turned off the engine
Followed by:
Trouble restarting
With eventual start-up some minutes later, it dies again on stopping... but not every time.
I've tried stopping hard and soft.. both ways it cuts out
To *HELP* 77L48 stalling on stop.
Old Jul 24, 2020 | 03:00 PM
77L48's Avatar
77L48
May I add also:
It is not always on the stop itself. Many times I have been stopped for a minute without issue and i feel ok and then it stalls out. So, it isn't specific to the stopping itself. Sometimes I have stopped and am idling when I stall.
Sorry if I forgot to mention this important detail
Old Jul 24, 2020 | 03:12 PM
Vibguy's Avatar
Vibguy
Is this statement true?: The car is idling, it stops, the gen light comes on, but all the gauges go dead - as if the car is off. I am trying to figure that one out. Thanks, I hope we can solve this for you.
Old Jul 24, 2020 | 03:27 PM
69 LT1's Avatar
69 LT1
what type is it.
you answered a question i was quoting someone else.
you didn’t answer my quote above.
you start with the simple check ( fuel ) and move on from there.
