New headlight vacuum lines
Old Jul 28, 2020 | 07:09 PM
nickster2213's Avatar
nickster2213
Default New headlight vacuum lines
Is it a big job to replace new headlight vacuum lines on my 1980 through the firewall? The two lines go into the wall with a rubber gasket.
Old Jul 28, 2020 | 07:32 PM
SwampeastMike's Avatar
SwampeastMike
Certainly not a big job. Secure the new line to the old line to the other with a couple wraps of strong duct tape. Clean both ends with lacquer thinner or rubbing alcohol before. Then just pull through from whichever direction is more convenient.
Old Jul 28, 2020 | 07:49 PM
nickster2213
Ok, thank you.
Old Jul 29, 2020 | 12:09 AM
derekderek's Avatar
derekderek
Another way to consider get some vacuum tube splice-connectors. Connect new tube to old and tape outside too. These things. Whole box at autozone is 5 bucks. https://www.ebay.com/itm/Dayco-Produ...Cclp%3A2334524
To New headlight vacuum lines
