windows
Old Aug 7, 2020 | 07:51 PM
VinniePG's Avatar
VinniePG
Default windows
Again, New to vettes, I have another mechanical question for those of you with morre expirence. 75 with power windows. Windows go up 3/4 of the way and then i have to manually pull them up. THe go down all the way. When I press the window buttons when the are 3/4 up, there is a continual clacking sound so I dont think its the motors. any ideas?
Old Aug 7, 2020 | 08:27 PM
MattoonVette's Avatar
MattoonVette
Living the Vette life....
Sounds like it may be the gear on the regulator itself or the gear on the motor. That would be my guess. There are also 3 bolts that bolt the motor to the regulator. I have seen these get loose and cause a similar issue to what you are describing.
