1978 headlight dimmer mechanism
Old Aug 20, 2020 | 03:06 PM
dwspender's Avatar
dwspender
Default 1978 headlight dimmer mechanism
I started by replacing the turn signal switch, which I believe is going okay. However, doing this I removed much of the housing around the steering column. I've managed to disable the headlight dimmer and there's a wind of spring type material activated by a 2" long, 1/4" dia rod that I don't know how to replace it's original position and make all things work. Any videos about this area of still shots that would show me what this left side of the steering column around the turn signal level and telescoping steering wheel lever should look like?
