68 Steering Telescopic Column
I am attempting to rebuild my column. I have bought new bearings (through corvette central as Doc is no longer selling them) I have started to rebuild the lower end of the steering column, and found that when the spring is placed against the bearing, I find it to be scraping. I wonder if I am missing a piece in between. As the Diagram that Jim Shea (thanks) has provided and found (#20) See attached; Packing to be missing. Is this a separate bushing? or they talking about the bushing "packing" or inner race? The spring presses against the lower bearing, with the retainer help holding it in. See my picture to see how I took it apart. Am I missing what I assume to be a washer/bushing?
As the lower bearing is stationary to the jacket, and the shaft rolls within it. Having the spring pressing against this face causes a slight scrape.
TLDR; Is there a bushing that goes in between the spring and lower bearing so that they can interface? as they scrape without one. If so, Can I have that part #.
Thanks!
IMGUR LINK https://imgur.com/a/BpjirF6 (Attached just looked horrible)
https://www.corvetteforum.com/forums...guru-help.html
M
M
