Front clip to door alignment
Old Sep 15, 2020 | 06:56 PM
Lachymac1's Avatar
Lachymac1
Default Front clip to door alignment
dddd
Old Sep 15, 2020 | 10:55 PM
crf311's Avatar
crf311
Hard to see with only 1 pic
Old Sep 16, 2020 | 07:24 AM
Lachymac1's Avatar
Lachymac1
sssss
Old Sep 16, 2020 | 08:38 AM
walleyfisher's Avatar
walleyfisher
shim the top door hinge out?
Old Sep 17, 2020 | 05:35 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Hold pressure on the high spot with your hand to see if it will settle into place...fiberglass body parts will distort when removed.
If your hand pressure will not cause it to sit flush with the door surface you may have to lightly sand fiberglass off the INSIDE of the clip and also sand the mating flange on the firewall to make the clip fit.
Let us know what happens.
Old Sep 17, 2020 | 07:40 PM
Lachymac1's Avatar
Lachymac1
Exactly what it was, had the clip off yesterday and there was a little bit of excess bonding glue on the inside of the clip!
To Front clip to door alignment
