1973 454 zo7
Old Sep 18, 2020 | 08:19 AM
LostCause's Avatar
LostCause
Cruising
Default 1973 454 zo7
I believe I have a 1973 z07 like everyone else but I want to be sure it’s the real deal. Here are some pictures of why I think it is.
Any comments would be appriciated.
The ride height is slightly higher than any others I’ve seen from the factory. Any comments or info would be appreciated.
There are only 7 leafs on this spring where most have 9.
Original 454 long block however some parts have been replaced, and some are in storage.
Not the 2 pin calipers it should have but I believe the last owner might have changed them out for the single pin ones to make replacement pads easier to locate.
Old Sep 18, 2020 | 08:21 AM
LostCause's Avatar
LostCause
Cruising
Any thoughts?
Old Sep 18, 2020 | 09:03 AM
LT-1 kid's Avatar
LT-1 kid
your far from proving anything with that info and pics, is it a manual, does it have ac, is there a tanks sticker
Old Sep 18, 2020 | 10:36 AM
kenba's Avatar
kenba
From: PHOENIX AZ. WHAT A MAN WON"T SPEND TO GIVE HIS ASS A RIDE
Yep its a corvette but it and the camera need a lot of work.
Old Sep 18, 2020 | 11:07 AM
Gordonm's Avatar
Gordonm
There is nothing there that provides any indication it is a Z07.
Old Sep 18, 2020 | 11:12 AM
Richard454's Avatar
Richard454
Just sayin- back in the day- I took my 9 leaf spring and pulled out a couple leafs to lower it...
Old Sep 18, 2020 | 12:40 PM
MelWff's Avatar
MelWff
There is no paperwork presented to validate it is a Z07 and the spring is meaningless as other have commented and you don't have the calipers.
Do the front springs have a tag on them?
Old Sep 18, 2020 | 01:16 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Any chance you have the tank sticker?
Old Sep 18, 2020 | 03:37 PM
LostCause's Avatar
LostCause
Cruising
it did come with a/c, and it does have the manual 4 speed now m22 gears, maybe converted from the m21? Suspicious about the a/c if not all zo7’s came without a/c. I can’t find conclusive documentation to prove otherwise.
Old Sep 18, 2020 | 03:40 PM
LostCause's Avatar
LostCause
Cruising
where on the spring would it look like 2 were removed? If so why does it still sit high like the front. And I doubt after all these years the tags are on the front springs still.. lost the tank sheet in a move between houses when I had the gas tank out of it.... 😩😩😩😩
Old Sep 18, 2020 | 04:21 PM
Easy Mike's Avatar
Easy Mike
Z07 was not available with factory air.
Old Sep 18, 2020 | 04:30 PM
LostCause's Avatar
LostCause
Cruising
never mind. It turns out I’m blind and counted the rear leaf spring wrong as 7 leafs but it’s 9. So yes my camera is a pos, and it is in need of a lot of work and I’m probably going blind.. anyway, who wants to buy it? It does have the original numbers matching short block and intake manifold in storage. There is a truck 454 short block with the original #matching heads and manual 4speed transmission in it.
Old Sep 18, 2020 | 06:01 PM
cv67's Avatar
cv67
St. Jude Donor '05
post a price and put it in the C3 for sale section all kinds of buyers here.
To 1973 454 zo7
